NAS542 bootloop after Debian/OMV (get a new firmware) (solved)
Depends on the tool you use to show the content
Oh, didn't know that, will go through all files again. Thought it depends on the monitor itselft and it would scroll automatically when i mark it with the mouse. Thank you. Unfortunately i have no vi, nano etc. All i have is "edit".
Oh yeah, there is alot more to see now. I post everything here so no need to scroll to the earlier post. Hope i didn't miss something.
/env/config:
#!/bin/sh
# use 'dhcp' to do dhcp in barebox and in kernel
# use 'none' if you want to skip kernel ip autoconfiguration
ip=dhcp
# or set your networking parameters here
#eth0.ipaddr=192.168.2.22
#eth0.netmask=255.255.255.0
eth0.serverip=192.168.1.70
#eth0.gateway=192.168.2.1
#eth0.ethaddr=00:0A:0B:0C:0D:0E
#eth1.ethaddr=00:1A:1B:1C:1D:1E
#eth2.ethaddr=00:2A:2B:2C:2D:2E
# can be either 'nfs', 'tftp' , 'nor' , 'nand' and 'sata'
kernel_loc=nand
#kernel_loc=nor
#kernel_loc=sata
# can be either 'net', 'nor' ,'initrd' , 'nand' and 'sata'
rootfs_loc=nand
#rootfs_loc=nor
#rootfs_loc=sata
# barebox images
uloaderimage=microloader-c2kevm.bin
bareboximage=barebox-c2kevm.bin
# MFG images for NAND flash
mfg_kernel_img=uImage_MFG
mfg_rootfs_img=rootfs_ubi.img_MFG
# can be either 'jffs2' , 'ubifs' or 'ext4
#rootfs_type=jffs2
rootfs_type=ubifs
#rootfs_type=ext4
rootfsimage=root.$rootfs_type-128k
# The image type of the kernel. Can be uimage, zimage, raw, or raw_lzo
kernelimage_type=uimage
kernelimage=uImage
#nfsroot="$eth0.serverip:/opt/work/busybox/rootfs_arm"
spi_parts="256k(uloader)ro,512k(barebox)ro,256k(env)"
spi_device="spi0.0"
nand_device="comcertonand"
#nand_parts="1024k(barebox)ro,1024k(bareboxenv),4M(kernel),-(rootfs)"
nand_parts="10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),110M(rootfs2),-(
#rootfs_mtdblock_nand=8
rootfs_mtdblock_nand=2
#nor_parts="128k(uloader)ro,512k(barebox)ro,128k(env),4M(kernel),48M(rootfs)"
#nor_device="comcertoflash.0"
#rootfs_mtdblock_nor=4
autoboot_timeout=3
usb3_internal_clk="yes"
bootargs="console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes "
bootargs="$bootargs mac_addr=$eth0.ethaddr,$eth1.ethaddr,$eth2.ethaddr"
# boot partition
next_bootfrom="1"
curr_bootfrom="2"
# partition layout
kernel_mtd_1=4
sysimg_mtd_1=5
kernel_mtd_2=6
sysimg_mtd_2=7
# MODEL ID for STG-540
MODEL_ID="B403"
fwversion_1="V5.20(ABAG.1)"
revision_1="50683"
modelid_1="B403"
core_checksum_1="2d4c3dbbbcb5ba8d40f7ed3591c1f3cc"
zld_checksum_1="db2960ca9ac1c1d09ea54ef3dc836989"
romfile_checksum_1="21E7"
img_checksum_1="7b31cf25f28a0a40d1463cdd5c3d35b9"
fwversion_2="V5.20(ABAG.1)"
revision_2="50683"
modelid_2="B403"
core_checksum_2="2d4c3dbbbcb5ba8d40f7ed3591c1f3cc"
zld_checksum_2="db2960ca9ac1c1d09ea54ef3dc836989"
romfile_checksum_2="21E7"
img_checksum_2="7b31cf25f28a0a40d1463cdd5c3d35b9"
ethaddr="5C:F4:AB:67:B1:BC"
eth2addr="5C:F4:AB:67:B1:BD"
serial_number="S150Z47005461"
change_boot_part="0"/env/bin/update:#!/bin/sh
type=""
device_type=""
check=n
mode=tftp
. /env/config
while getopt "ht:d:f:a:s:m:c" Option
do
if [ ${Option} = t ]; then
type=${OPTARG}
elif [ ${Option} = d ]; then
device_type=${OPTARG}
elif [ ${Option} = f ]; then
imagename=${OPTARG}
elif [ ${Option} = a ]; then
address=${OPTARG}
elif [ ${Option} = s ]; then
size=${OPTARG}
elif [ ${Option} = c ]; then
check=y
elif [ ${Option} = m ]; then
mode=${OPTARG}
else
. /env/bin/_update_help
exit 0
fi
done
if [ x${type} = xkernel ]; then
image=$kernelimage
elif [ x${type} = xkernel1 ]; then
image=$kernelimage
elif [ x${type} = xkernel2 ]; then
image=$kernelimage
elif [ x${type} = xrootfs ]; then
image=$rootfsimage
elif [ x${type} = xrootfs1 ]; then
image=$rootfsimage
elif [ x${type} = xrootfs2 ]; then
image=$rootfsimage
elif [ x${type} = xbarebox ]; then
image=$bareboximage
if [ x${image} = x ]; then
image=barebox.bin
fi
elif [ x${type} = xuloader ]; then
image=$uloaderimage
elif [ x${type} = xbareboxenv ]; then
image=$bareboxenvimage
image=bareboxenv.bin
fi
type=env
else
exit 1
fi
if [ x${imagename} != x ]; then
image=${imagename}
fi
if [ x${device_type} = xnand ]; then
part=/dev/nand0.${type}.bb
elif [ x${device_type} = xnor ]; then
part=/dev/nor0.${type}
else
exit 1
fi
if [ x${mode} != xtftp ] && [ x${mode} != xxmodem ] && [ x${mode} != xddr ]; the
echo "unsupported mode ${mode}."
exit 1
fi
. /env/bin/_update || exit 1
if [ x${check} = xy ]; then
if [ x${mode} = xddr ]; then
crc32 -f $part
crc32 $address+$size
elif [ x${mode} = xtftp ]; then
crc32 -f $part
else
crc32 -f $image -F $part
fi
else
true
fi/env/bin/update_rootfs#!/bin/sh/env/bin/_update
. /env/bin/update -t rootfs -d $1#!/bin/sh
uloader 2011.06.0 (May 20 2014 - 16:36:41)
if [ -z "$part" -o -z "$address" -o -z "$size" ]; then
Board: Mindspeed C2000define \$part, \$address and \$size"
c2k_spi_probe exit 1
fi
Copying Barebox from SPI Flash(bootopt=0)
if [ -z "$part" -o -z "$image" ]; then
echo "define \$part and \$image"
exit 1
fi
fi
if [ ! -e "$part" ]; then
echo "Partition $part does not exist"
exit 1
fi
if [ x$mode = xtftp ]; then
if [ x$ip = xdhcp ]; then
dhcp
fi
ping $eth0.serverip
if [ $? -ne 0 ] ; then
echo "Server did not reply! Update aborted."
exit 1
fi
elif [ x$mode = xxmodem ]; then
loadb -f $image -c
echo "loadb failed or cancelled! Update aborted."
exit 1
fi
fi
unprotect $part
echo
echo "erasing partition $part"
echo
erase $part
if [ x$mode = xddr ]; then
echo
echo "flashing $size@$address to $part"
echo
else
echo
echo "flashing $image to $part"
echo
fi
tftp $image $part
echo "!!!Probable use of old NAND layout.!!!"
echo "Use 'erase_old_nand_fmt' command to clean NAND."
exit 1
fi
elif [ x$mode = xddr ]; then
memcpy $address -d $part 0 $size
else
cp $image $part
fi
protect $part/env/bin/update_uloader#!/bin/sh
. /env/bin/update -t uloader -d $1
/env/bin/b0#!/bin/sh/env/bin/hush_hack
. /env/config
if [ x$1 = xnand ]; then
rootfs_loc=nand
kernel_loc=nand
#elif [ x$1 = xnor ]; then
# rootfs_loc=nor
# kernel_loc=nor
#elif [ x$1 = xsata ]; then
# rootfs_loc=sata
# kernel_loc=sata
#elif [ x$1 = xnfs ]; then
# rootfs_loc=net
# kernel_loc=nfs
elif [ x$1 = xtftp ]; then
rootfs_loc=net
kernel_loc=tftp
fi
bootargs="$bootargs ip=dhcp"
elif [ x$ip = xnone ]; then
bootargs="$bootargs ip=none"
else
bootargs="$bootargs ip=$eth0.ipaddr::$eth0.gateway:$eth0.netmask:::"
fi
if [ x$rootfs_loc = xnet ]; then
bootargs="$bootargs root=/dev/nfs nfsroot=$nfsroot,v3,tcp noinitrd"
elif [ x$rootfs_loc = xinitrd ]; then
bootargs="$bootargs root=/dev/ram0 rdinit=/sbin/init"
elif [ x$rootfs_loc = xsata ]; then
bootargs="$bootargs root=/dev/sda2 rootfstype=$rootfs_type rw noinitrd"
else
if [ x$rootfs_loc = xnand ]; then
rootfs_mtdblock=$rootfs_mtdblock_nand
else
rootfs_mtdblock=$rootfs_mtdblock_nor
fi
if [ x$rootfs_type = xubifs ]; then
if [ -z $ubiroot ]; then
ubiroot="rootfs"
fi
bootargs="$bootargs root=ubi0:$ubiroot ubi.mtd=$rootfs_m
else
fi
else
bootargs="$bootargs root=/dev/mtdblock$rootfs_mtdblock"
fi
bootargs="$bootargs rootfstype=$rootfs_type rw noinitrd"
fi
#if [ -n $nor_parts ]; then
# mtdparts="${mtdparts}${nor_device}:${nor_parts}"
#fi
if [ -n $spi_parts ]; then
mtdparts="${mtdparts}${spi_device}:${spi_parts}"
fi
if [ -n $nand_parts ]; then
if [ -n ${mtdparts} ]; then
mtdparts="${mtdparts};"
fi
mtdparts="${mtdparts}${nand_device}:${nand_parts}"
fi
if [ -n $mtdparts ]; then
bootargs="${bootargs} mtdparts=${mtdparts}"
fi
if [ -e /dev/ram0 ]; then
if [ ! -e /dev/ram0.kernelraw ]; then
# arm raw kernel images are usually located at sdram start + 0x8000
addpart /dev/ram0 8M@0x8000(kernelraw)
fi
if [ ! -e /dev/ram0.kernel ]; then
# Here we can safely put the kernel without risking of overwriting it
# while extracting
addpart /dev/ram0 8M@8M(kernel)
fi
fi
# update curr_bootfrom according to next_bootfrom
if [ x$next_bootfrom != x$curr_bootfrom ]; then
curr_bootfrom=$next_bootfrom
fi
if [ x$kernel_loc = xnfs ] || [ x$kernel_loc = xtftp ]; then
dhcp
fi
if [ $kernelimage_type = uimage ]; then
netload="/dev/ram0.kernel"
elif [ $kernelimage_type = zimage ]; then
elif [ $kernelimage_type = raw ]; then
netload="/dev/ram0.kernelraw"
elif [ $kernelimage_type = raw_lzo ]; then
else
echo "error: set kernelimage_type to one of 'uimage', 'zimage',
exit 1
fi
$kernel_loc $kernelimage $netload || exit 1
kdev="$netload"
elif [ x$kernel_loc = xnor ]; then
kdev="/dev/nor0.kernel"
elif [ x$kernel_loc = xnand ]; then
kdev="/dev/nand0.kernel${curr_bootfrom}.bb"
elif [ x$kernel_loc = xsata ]; then
addpart /dev/mem 3M@0x3008000(uImage)
sata read 3008000 1 5000
kdev="/dev/mem.uImage"
sata stop
else
echo "error: set kernel_loc to one of 'nfs', 'tftp', 'nand' or 'nor'"
exit 1
fi
if [ -n $usb3_internal_clk ]; then
bootargs="$bootargs usb3_internal_clk=$usb3_internal_clk"
fi
# set fan speed to 20% to avoid the irregular jitter
mw 0x90470058 0x05000000
mw 0x90458000 0x80000001
mw 0x90458028 0x80001388
mw 0x9045802C 0x00000fa0
echo "booting kernel of type $kernelimage_type from $kdev"
if [ x$kernelimage_type = xuimage ]; then
bootm $kdev
echo " Failed."
# change partition and retry it
if [ "$curr_bootfrom" = "1" ]; then
curr_bootfrom=2
elif [ "$curr_bootfrom" = "2" ]; then
curr_bootfrom=1
else
curr_bootfrom=1
fi
bootm $kdev
elif [ x$kernelimage_type = xzimage ]; then
bootz $kdev
elif [ x$kernelimage_type = xraw ]; then
if [ $kernel_loc != net ]; then
cp $kdev /dev/ram0.kernelraw
fi
bootu /dev/ram0.kernelraw
elif [ x$kernelimage_type = xraw_lzo ]; then
unlzo $kdev /dev/ram0.kernelraw
fi
####### do error handling here (for MFG process) ######
# stop watchdog timer of MCU (37: MCU normal mode(not burning), 39: MCU sys boot
mw 0x904700D0 0x010000A0
# get ip address from dhcp server
dhcp
# update kernel1 partition
/env/bin/update -t kernel1 -d nand -f $mfg_kernel_img
if [ $? != 0 ]; then
mw 0x904700D0 0x020000A0
exit
fi
# update kernel2 partition
/env/bin/update -t kernel2 -d nand -f $mfg_kernel_img
exit
fi
if [ 0 -eq 1 ]; then # rootfs should not be downloaded here, use rootfs key i
# update rootfs1 partition
/env/bin/update -t rootfs1 -d nand -f $mfg_rootfs_img
exit
fi
# update rootfs2 partition
/env/bin/update -t rootfs2 -d nand -f $mfg_rootfs_img
exit
fi
fi
#/env/bin/blink_sys_led
while [ 1 ]
do
# turn off sys led
mw 0x904700D0 0x000000A0
sleep 1
# turn on sys led
sleep 1
donenand -a /dev/nand0.*/env/bin/_update_help#!/bin/sh/env/bin/init
echo "usage: update -t <kernel|rootfs|barebox|bareboxenv> -d <nor|nand> [-m tftp
echo "update tools."
echo ""
echo "options"
echo " -c to check the crc32 for the image and flashed one"
echo ""
echo "default mode is tftp"
echo "type update -t uloader -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagename|-a
echo "type update -t barebox -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagename|-a
echo "type update -t kernel -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagename|-a
echo "type update -t rootfs -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagename|-a
echo "type update -t bareboxenv -d <nor|nand> [-m tftp|xmodem|ddr] [-f imagename#!/bin/sh/env/bin/update_barebox
PATH=/env/bin
export PATH
. /env/config
#if [ -e /dev/nor0 -a -n "$nor_parts" ]; then
# addpart /dev/nor0 $nor_parts
#fi
#if [ -e /dev/disk0 -a -n "$disk_parts" ]; then
# addpart /dev/disk0 $disk_parts
#fi
if [ -e /dev/spi0 -a -n "$spi_parts" ]; then
addpart /dev/spi0 $spi_parts
fi
if [ -e /dev/nand0 -a -n "$nand_parts" ]; then
addpart /dev/nand0 $nand_parts
# Uh, oh, hush first expands wildcards and then starts executing
# commands. What a bug!
source /env/bin/hush_hack
fi
if [ -f /env/bin/init_board ]; then
/env/bin/init_board
fi
echo "Disabling eee function of phy 4 ..."
phy write 4 0x1F 0x0000
phy write 4 0x00 0x8000
#Wait 20ms for PHY reset
sleep 1
phy write 4 0x1F 0x0005
phy write 4 0x05 0x8b85
phy write 4 0x06 0x0ae2
phy write 4 0x1F 0x0007
phy write 4 0x1E 0x0020
phy write 4 0x15 0x1008
phy write 4 0x0D 0x0007
phy write 4 0x0E 0x003c
phy write 4 0x0D 0x4007
phy write 4 0x0E 0x0000
echo "Disabling eee function of phy 6 ..."
phy write 6 0x1F 0x0000
phy write 6 0x00 0x8000
sleep 1
phy write 6 0x1F 0x0005
phy write 6 0x05 0x8b85
phy write 6 0x06 0x0ae2
phy write 6 0x1F 0x0007
phy write 6 0x1E 0x0020
phy write 6 0x15 0x1008
phy write 6 0x0D 0x0007
phy write 6 0x0E 0x003c
phy write 6 0x0D 0x4007
phy write 6 0x0E 0x0000
echo
echo -n "Hit any key to stop autoboot: "
timeout -a $autoboot_timeout
exit
fi
boot#!/bin/sh
. /env/bin/update -t barebox -d $1
/env/bin/b2#!/bin/sh
. /env/config
next_bootfrom="2"
rootfs_loc=nand
kernel_loc=nand
# rootfs_loc=nor
# kernel_loc=nor
# rootfs_loc=sata
# kernel_loc=sata
# rootfs_loc=net
# kernel_loc=nfs
rootfs_loc=net
kernel_loc=tftp
fi
else
fi
else
else
fi
ubiroot="rootfs"
fi
else
fi
else
fi
fi
#fi
fi
fi
fi
fi
fi
# while extracting
fi
fi
fi
dhcp
fi
else
exit 1
fi
kdev="$netload"
sata stop
else
exit 1
fi
fi
bootm $kdev
echo " Failed."
curr_bootfrom=2
curr_bootfrom=1
else
curr_bootfrom=1
fi
bootm $kdev
bootz $kdev
fi
fi
dhcp
exit
fi
exit
fi
exit
fi
exit
fi
fi
while [ 1 ]
do
# turn off sys led
sleep 1
# turn on sys led
sleep 1
done
/env/bin/b1#!/bin/sh
. /env/config
next_bootfrom="1"
rootfs_loc=nand
kernel_loc=nand
# rootfs_loc=nor
# kernel_loc=nor
# rootfs_loc=sata
# kernel_loc=sata
# rootfs_loc=net
# kernel_loc=nfs
rootfs_loc=net
kernel_loc=tftp
fi
else
fi
else
else
fi
ubiroot="rootfs"
fi
else
fi
else
fi
fi
#fi
fi
fi
fi
fi
fi
# while extracting
fi
fi
fi
dhcp
fi
else
exit 1
fi
kdev="$netload"
sata stop
else
exit 1
fi
fi
bootm $kdev
echo " Failed."
curr_bootfrom=2
curr_bootfrom=1
else
curr_bootfrom=1
fi
bootm $kdev
bootz $kdev
fi
fi
dhcp
exit
fi
exit
fi
exit
fi
exit
fi
fi
while [ 1 ]
do
# turn off sys led
sleep 1
# turn on sys led
sleep 1
done0 -
/env/bin/boot#!/bin/sh/env/bin/update_kernel
. /env/config
rootfs_loc=nand
kernel_loc=nand
# rootfs_loc=nor
# kernel_loc=nor
# rootfs_loc=sata
# kernel_loc=sata
# rootfs_loc=net
# kernel_loc=nfs
rootfs_loc=net
kernel_loc=tftp
fi
else
fi
else
else
fi
if [ x$next_bootfrom = x2 ]; then
bootargs="$bootargs drive_bays=4 syno_hw_version=NAS542v10 ihd_n
rootfs_type=ext4
elif [ x$rootfs_type = xubifs ]; then
ubiroot="rootfs"
fi
else
fi
else
fi
fi
#fi
fi
fi
fi
fi
fi
# while extracting
fi
fi
fi
dhcp
fi
else
exit 1
fi
kdev="$netload"
sata stop
else
exit 1
fi
fi
bootm $kdev
echo " Failed."
curr_bootfrom=2
curr_bootfrom=1
else
curr_bootfrom=1
fi
bootm $kdev
bootz $kdev
fi
fi
dhcp
exit
fi
exit
fi
exit
fi
exit
fi
fi
while [ 1 ]
do
# turn off sys led
sleep 1
# turn on sys led
sleep 1
done#!/bin/sh
. /env/bin/update -t kernel -d $10 -
Hmm. Reading that /env/config file, I wonder if 'setenv' is as easy as editing that file? There I read
<div># boot partition<br>next_bootfrom="1"<br>curr_bootfrom="2"</div><div></div>
and I can nowhere find that it's overwritten by a readenv, or something like that.
WOHOOOO.......a little bit.After alot of trying i found out how to save in the "edit" tool (this is stored till a reboot). Close window with "CTRL+C" and save with "CTRL+D". Now i need a little hint what to do with that, cause simply "boot" is the same as before (cause he already switches to the second one).I tried this change with loading the uImage.521 but this gives me an "ubiattach error" (wasn't that before? attached uImage.txt)After that i tried with my SDcard and "boot". It booted to the debian login prompt. I am happy about that but this doesn't really help to get the original firmware back.0
saveenv might help.
Combining your debian bootlog with the bootscripts, I'd try
<p>bootargs="console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes mac_addr=,, ip=dhcp root=ubi0:rootfs ubi.mtd=2,2048 rootfstype=ubifs rw noinitrd mtdparts=spi0.0:256k(uloader)ro,512k(barebox)ro,256k(env);comcertonand:10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),110M(rootfs2),-(reserved) usb3_internal_clk=yes"</p><p><br></p><p><insert tftp boot commands></p>
Saveenv works here, great.I exchanged the first bootargs line in the config file with yours, the second bootargs line i didn't touch. Unfortunately it seems i had problems with the line length, output after "Starting kernel" was:
commandline: console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes mac_addr=,,<br>
So i split your line in parts, but i am not shure if i have done it right.bootargs="console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes ,"
bootargs="mac_addr=,, ip=dhcp root=ubi0:rootfs ubi.mtd=2,"
bootargs="2048 rootfstype=ubifs rw noinitrd"
bootargs="mtdparts=spi0.0:256k(uloader)ro,512k(barebox)ro,256k(env);"
bootargs="comcertonand:10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),"
bootargs="110M(rootfs2),-(reserved) usb3_internal_clk=yes"The result was the same to me. Log of the second try with all the lines is attached.0 -
Eh, no. Have a look in /env/bin/boot, there you can see how the bootargs is build. Something like
<p>bootargs="key=value"</p><p><br></p><p>bootargs="${bootargs} key2=value2"</p><p><br></p><p>bootargs="${bootargs} key3=value3"<br></p>
Here each time the old bootargs argument is injected in the new one. If you split a value, like you did in the insanely long 'mtdparts' key, make sure you don't add a space:
<p>bootargs="key=firstpartofvalue"</p><p><br></p><p>bootargs="${bootargs}nextpartofvalue"</p><p></p>
I think you can look at the result with 'echo ${bootparts}'. (That's equal to 'echo $bootparts, but by use of curly braces the statement doesn't have to end with a space or newline)
Yet your commandline is different than I would expect. Seeing your commands above I'd expect it to be
<p>110M(rootfs2),-(reserved) usb3_internal_clk=yes <br></p><p></p>
but instead it's not changed at all.
Reading your bootlog I see your bootargs commands, followed by
<p>bootargs="$bootargs mac_addr=$eth0.ethaddr,$eth1.ethaddr,$eth2.ethaddr"<br></p><p></p>
Where does that come from? Did you type it?
Anyway, somehow it's reset. I searched for an old version of the barebox documentation, and found it here. The 'global' keyword suggests that variables in scripts are handled differently than variables on the command line. So I thought of 2 options. First prepare everything:
<p>dhcp<br></p><p>eth0.serverip=192.168.178.11<br></p><p>addpart /dev/mem 8M@0x8000(kernelraw)<br></p><p>addpart /dev/mem 8M@8M(kernel)<br></p><p>netload="/dev/mem.kernel"<br></p><p>tftp uImage.521 $netload<br><br></p><p>bootargs="console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes ,"<br></p><p>bootargs="${bootargs} mac_addr=,, ip=dhcp root=ubi0:rootfs ubi.mtd=2,"<br></p><p>bootargs="${bootargs}2048 rootfstype=ubifs rw noinitrd"<br></p><p>bootargs="${bootargs} mtdparts=spi0.0:256k(uloader)ro,512k(barebox)ro,256k(env);"<br></p><p>bootargs="${bootargs}comcertonand:10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),"<br></p><p>bootargs="${bootargs}110M(rootfs2),-(reserved) usb3_internal_clk=yes"<br></p>
Check if bootargs is ok:
echo ${bootargs}
Then there are 2 options:<p>bootargs=${bootargs} bootm ${netload}</p>
or
<p>global bootargs=${bootargs}</p><p><br></p><p>bootm ${netload}<br></p>
- 435 Beta Program
- 183 Nebula Ideas
- 120 Nebula Status and Incidents
- 6.2K Security
- 440 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 433 News and Release
- 84 About Community
- 91 Security Highlight
