NAS542 bootloop after Debian/OMV (get a new firmware) (solved)
  • Triu
    Triu Posts: 46 image  Freshman Member
    edited June 2019
    I have changed this bootargs in /env/config. There was this second line so i haven't changed it.
    Now i understand this injection and deleted the old stuff and have now only your bootargs lines in the config.
    Your first option works, but at the end the beeper gives a beep every second. (Log attached) Something is better now, cause no mtd7 or ubiattach errors.
    Log.txt 33.2K
  • Mijzelf
    Mijzelf Posts: 2,990 image  Guru Member
    Have you checked if the webinterface is running? If yes, upgrade the firmware, and it might be repaired. If that works, upgrade the firmware twice (with a reboot in between) to have both 'slots' filled with valid data.
  • Triu
    edited June 2019
    Unfortunately no interface. I tried with IP and "NAS542". With my NAS520 (yes i have another one) the appropriate IP works. Some of the last lines in the log tell "the interface None/bon0/bond1 is down or unusable", can i start the interface manually? At the end of the Log i have access to the filesystem.  If i type help i get:
    Built-in commands:
            . : [ [[ alias bg break cd chdir continue eval exec exit export
            false fg hash help jobs kill let local printf pwd read readonly
            return set shift source test times trap true type ulimit umask
            unalias unset wait
    On a later try the annoying beeper is quiet and i found here in the forum how to restart the webserver with:
    </code><code>/etc/init.d/httpd.sh restart
    But doesn't change anything. Output is:
    / # /etc/init.d/httpd.sh restart
    httpd[2380]: [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
    httpd[2380]: [warn] RSA server certificate CommonName (CN) `NAS542' does NOT match server name!?
    httpd[2380]: [error] mod_auth_zyxel: initialized.
    httpd[2492]: [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
    httpd[2492]: [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
    httpd[2492]: [warn] RSA server certificate CommonName (CN) `NAS542' does NOT match server name!?
    httpd[2492]: [error] mod_auth_zyxel: initialized.
    / # httpd[2494]: [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
    httpd[2494]: [warn] RSA server certificate CommonName (CN) `NAS542' does NOT match server name!?
    httpd[2494]: [error] mod_auth_zyxel: initialized.
  • MrDini
    MrDini Posts: 12 image  Freshman Member
    Second Anniversary
    Would you mind posting a dmesg and ifconfig command output? (mask out the MAC address in the latter)
  • Triu
    edited June 2019
    There are two IPs i get, the first is that from the "dhcp" command in the beginning. At this time there is no dmesg and ifconfig. After booting the uImage the NAS will be shown in my router as NAS542 with another IP. (it is on the same port, cause only one port is connected). Then i can do the dmesg and ifconfig.
    / # ifconfig
    egiga0    Link encap:Ethernet  HWaddr 00:ED:CD:EF:AA:CC
              inet6 addr: fe80::2ed:cdff:feef:aacc/64 Scope:Link
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
              RX packets:79 errors:0 dropped:72 overruns:0 frame:0
              TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:1000
              RX bytes:4740 (4.6 KiB)  TX bytes:468 (468.0 B)
    egiga1    Link encap:Ethernet  HWaddr 00:2A:2B:2C:2D:2E
              UP BROADCAST MULTICAST  MTU:1500  Metric:1
              RX packets:0 errors:0 dropped:0 overruns:0 frame:0
              TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:0 (0.0 B)  TX bytes:328 (328.0 B)
    lo        Link encap:Local Loopback
              inet addr:127.0.0.1  Mask:255.0.0.0
              inet6 addr: ::1/128 Scope:Host
              UP LOOPBACK RUNNING  MTU:16436  Metric:1
              RX packets:5 errors:0 dropped:0 overruns:0 frame:0
              TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:0
              RX bytes:1780 (1.7 KiB)  TX bytes:1780 (1.7 KiB)
    Hmmmm, shouldn't there be the IP4 adress i see on my router? At the moment it is 192.168.178.53
  • Mijzelf
    The IP which is assigned to barebox is dropped when the Linux kernel re-initializes the ethernet port. I think the port even has another MAC, as barebox dhcp has assigned a random MAC, and the firmware is supposed to assign the 'real' MAC, although it hasn't done so. So I suppose this are 2 new, random MACs. You can for now assign an IP manually:
    ifconfig egiga0 <ip-address> netmask 255.255.255.0
  • Triu
    edited June 2019
    I tought about that but then discarded this because my router told me the IP. How can the NAS not have it when the router tells me? (maybe an old entry?) Anyway, it works. ;)
    Now i am on the webinterface but can't change the password, a window pops up which tells me i have to change it, i put in a new one and will then be redirected to the login screen again. The new password doesn't work. When i click on "don't show me this message again" i can login with 1234 without the popup. Then i click on settings (i think here would be the update tool) but there is only the possibility to change password, but when i do an error occurs and i think this is the reason why i see not more settings.
    There was another Thread here with that problem, i will search and try.
    Edit1: Have found that someone had problems with an antivirus tool, but i have none, all i have is uBlock origin but also when disabled, i can't change password. The second solution in another Thread was the factory reset, which i think i can ignore.
    Edit2: Tried to change it through serial with "passwd admin", i got a confirmation but doesn't work on the webinterface. Even when i restart the webinterface with "httpd.sh restart"
    Edit3: Because i saw some threads mentioning passwords longer than 15 characters or something with special characters, i use a really simple "Hallo4321" for the moment, just to let you know this is not the problem.
    Edit4: I saw in the manual that there are different desktops for admin and users. I have a user desktop although i'm logged in as admin. I have found a command with "cat" which shows me which user is in which group, unfortunately i can't post it here because i get a "you are blocked" notification from the forum software. Anyway the output of this command is:
    admin:x:501:500:type&admin:/home/shares:/bin/sh
  • Mijzelf
    The webinterface uses the samba password, which has it's own hash table. You can try
    smbpasswd admin
    Two desktops? Do you know which firmware you are running?
  • Triu
    edited June 2019
    I'm using a single monitor here (Laptop), also tested to change password in webinterface with an android tablet before, same results.
    Changed password with "smbpasswd admin" and logged in with new password, but have again only the "user desktop".
    The firmware i can see only on the serial monitor, should be 520ABAG1b2. When i click in the webinterface on "about this NAS" nothing happens. (maybe restrictions to the user desktop?).
    / # ifconfig egiga0 192.168.178.53 netmask 255.255.255.0
    2000/01/20 15:35:14 [ipnotify] : rth->rta_type = 1, IFA_ADDRESS=1, IFA_LOCAL=2
    2000/01/20 15:35:14 [ipnotify] : detect a new IP and execute /sbin/ipnotify_exec.sh
    / # [ipnotify_exec.sh]: ******** detect egiga0 new IP********
    [20/Jan/2000:15:35:15]  [network_common.py.pre](check_link_status)(275): the interface None is down or unusable
    [20/Jan/2000:15:35:15]  [network_common.py.pre](check_link_status)(275): the interface bond0 is down or unusable
    [20/Jan/2000:15:35:15]  [network_common.py.pre](check_link_status)(275): the interface bond1 is down or unusable
    Traceback (most recent call last):
      File "<string>", line 1, in <module>
      File "/home/release-build/NAS542/520ABAG1b2/sysapps/web_framework/build/models/network_common.py.pre", line 248, in check_and_write_dns
      File "/home/release-build/NAS542/520ABAG1b2/sysapps/web_framework/build/lib/config_api.py.pre", line 100, in modify_conf_value
    TypeError: argument of type 'NoneType' is not iterable
    httpd[2686]: [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
    httpd[2686]: [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
    httpd[2686]: [warn] RSA server certificate CommonName (CN) `NAS542' does NOT match server name!?
    httpd[2686]: [error] mod_auth_zyxel: initialized.
    httpd[2703]: [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
    httpd[2703]: [warn] RSA server certificate CommonName (CN) `NAS542' does NOT match server name!?
    httpd[2703]: [error] mod_auth_zyxel: initialized.
    Maybe i will be redirected to the wrong URL? If i search for the IP (192.168.178.53) it will give me "http://192.168.178.53/DYNAMIC_STRING/desktop,/" which is the "user desktop". Is there a possibility to switch the desktop by another URL? On my NAS520 it is "http://192.168.178.60/r51163,/desktop,/"
    Or has it to do with authentication? When i change IP, there is an error: mod_auth_zyxel
    2000/01/20 16:24:37 [ipnotify] : rth->rta_type = 1, IFA_ADDRESS=1, IFA_LOCAL=2
    2000/01/20 16:24:37 [ipnotify] : detect a new IP and execute /sbin/ipnotify_exec.sh
    [20/Jan/2000:16:24:38]  [network_common.py.pre](check_link_status)(275): the interface None is down or unusable
    [20/Jan/2000:16:24:38]  [network_common.py.pre](check_link_status)(275): the interface bond0 is down or unusable
    [20/Jan/2000:16:24:38]  [network_common.py.pre](check_link_status)(275): the interface bond1 is down or unusable
    httpd[31997]: [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
    httpd[31997]: [warn] RSA server certificate CommonName (CN) `NAS542' does NOT match server name!?
    httpd[31997]: [error] mod_auth_zyxel: initialized.
    httpd[32269]: [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
    httpd[32269]: [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
    httpd[32269]: [warn] RSA server certificate CommonName (CN) `NAS542' does NOT match server name!?
    httpd[32269]: [error] mod_auth_zyxel: initialized.
    httpd[32271]: [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
    httpd[32271]: [warn] RSA server certificate CommonName (CN) `NAS542' does NOT match server name!?
    httpd[32271]: [error] mod_auth_zyxel: initialized.
  • Mijzelf
    Yeah, possibly. You can try a factory reset:
    /usr/local/btn/reset_and_reboot.sh<br>
    The IP is assigned to a MAC address, until the lease is expired, or the DHCP client checks out, which doesn't happen. Meanwhile the NAS switched MAC, but the router doesn't know. And even if the NAS didn't change it's MAC, the bootloader doesn't tell it's IP to Linux, so Linux will simply drop all traffic to an IP which it doesn't know.
