Plex.TV for NAS326??
  • emau74
    emau74 Posts: 53 image  Ally Member
    Friend Collector Third Anniversary
    so I did but I couldn't install plex, so I wanted help not to tell me how I should do it because I read the guide
  • Mijzelf
    Mijzelf Posts: 3,013 image  Guru Member
    So be it.
  • emau74
    so the problem remains, I followed the guide for nas326, why can't I install it?
  • landtools
    landtools Posts: 2 image  Freshman Member
    Second Anniversary
    Buongiorno a Tutti, è possibile avere una mano ad installare plex sul mio nas 326 ??
  • Gennaro83
    Gennaro83 Posts: 1 image  Freshman Member
    Buongiorno ragazzi io ho un zyxel 326 vorrei inserire plex nelle app qualcuno può aiutarmi grazie mille.
  • Jose3745
    Jose3745 Posts: 2 image  Freshman Member
    hola me podeis decir como instalar plex en Zyxel Nas 326 o si hay tutoriales con inagenes o algo gracias
  • Jose3745
    hay alguien que alla puesto Emby
  • baybora
    baybora Posts: 29 image  Freshman Member
    Dear Mijzelf,
    Please check the photos below.
    I did everything which you said. But at the last step i cannot the plex tv app.
    Where is my mistake?
    PS: I have Nas326
  • Mijzelf
    Don't know which instructions you are referring to. But web_prefix shouldn't have an extension. And the size doesn't fit either. The 'real one' is only 54 bytes.
  • baybora
    edited December 2019
    I am trying to use exactly your way.
    I am entering the link which below your post.
    Than, I am passing the "NAS326" section, than "zypkg", than "5,21"  (I thought, highest number is the updated one ), Than push to link " MetaRepository_20181001_arm_015.zpkg" to download it.
    After download, ı renamed it from "MetaRepository_20181001_arm_015.zpkg" to  "web_prefix"
    For last step, I am creating a folder named "zy-pkgs" in main "admin" folder.
    That is all.
    Am I wrong ?
