I have the NSA 325 V2 and placed raid1 on disk1 while disk2 had not yet a volume
  • Mijzelf
    Mijzelf Posts: 2,956  Guru Member
    mount: you must specify the filesystem type
    Try
    mount -t ext4 /dev/sda2 /mnt/mountpoint
    sh: copy: not found
    Did I really write copy? The command is cp.
  • Carlusha99
    Carlusha99 Posts: 39  Freshman Member
    /mnt/mountpoint # mdadm --stop /dev/md0 && mount -t ext4 /dev/sda2 /mnt/mountpoidmes
    nt
    mdadm: stopped /dev/md0
    mount: wrong fs type, bad option, bad superblock on /dev/sda2,
           missing codepage or helper program, or other error
           In some cases useful info is found in syslog - try
           dmesg | tail  or so
    /mnt/mountpoint #
    /mnt/mountpoint # cp -a * /i-data/3cc8587e/
    cp: can't stat '*': No such file or directory
    cp *cp
  • Carlusha99
    Just to clarify this was the original return information
    /mnt/mountpoint # mdadm --stop /dev/md0 && mount -t ext4 /dev/sda2 /mnt/mountpoint
           dmesg | tail  or so
    /mnt/mountpoint #
  • Mijzelf
    What says
    <div>mkdir /mnt/mountpoint</div><div><br></div><div>mdadm --stop /dev/md0 && mount -t ext4 /dev/sda2 /mnt/mountpoint</div><div><br></div><div>dmesg | tail<br></div>
  • Carlusha99
    Hi Mijzelf
    I have entered
    ~ # mkdir /mnt/mountpoint
    mkdir: can't create directory '/mnt/mountpoint': File exists
    ~ # mdadm --stop /dev/md0 && mount -t ext4 /dev/sda2 /mnt/mountpoint
    dmesg mount: wrong fs type, bad option, bad superblock on /dev/sda2,
           dmesg | tail  or so
    dmesg | tail
    md: md0 stopped
    #              HD0 awaked by mount  !        #
    ---> HD0 back to green on, off blink
    Uncached vma c8cffb78 (addr 4028b000 flags 080000d5 phy 1dd32000) from pid 674
    Uncached vma c8cffb78 (addr 4028b000 flags 080000d5 phy 1dd63000) from pid 674
    Uncached vma c8cffb78 (addr 4028b000 flags 080000d5 phy 1dd60000) from pid 674
    EXT4-fs (sda2): VFS: Can't find ext4 filesystem
  • Mijzelf
    Apparently it's not ext4. Try ext3 instead.
  • Carlusha99
    Hoi Mijzelf:
    BusyBox v1.17.2 (2017-06-23 10:40:08 CST) built-in shell (ash)
    Enter 'help' for a list of built-in commands.
    ~ # mdadm --stop /dev/md0 && mount -t ext2 /dev/sda2 /mnt/mountpoint
           dmesg | tail  or so
    ~ # mdadm --stop /dev/md0 && mount -t ext3 /dev/sda2 /mnt/mountpoint
           dmesg | tail  or so
    ~ # dmesg | tail
    Uncached vma c8c59968 (addr 4028b000 flags 080000d5 phy 1dd32000) from pid 2111
    Uncached vma c8c59968 (addr 4028b000 flags 080000d5 phy 1dd63000) from pid 2111
    Uncached vma c8c59968 (addr 4028b000 flags 080000d5 phy 1dd60000) from pid 2111
    VFS: Can't find an ext2 filesystem on dev sda2.
    md: md0 stopped.
    md: md0 stopped.
    VFS: Can't find ext3 filesystem on dev sda2.
    Uncached vma d750dc28 (addr 4028b000 flags 080000d5 phy 1dd32000) from pid 2256
    Uncached vma d750dc28 (addr 4028b000 flags 080000d5 phy 1dd63000) from pid 2256
    Uncached vma d750dc28 (addr 4028b000 flags 080000d5 phy 1dd60000) from pid 2256
    ~ # mount -t ext1 /dev/sda2 /mnt/mountpoint
    mount: unknown filesystem type 'ext1'
    ~ # mdadm --stop /dev/md0 && mount -t ext1 /dev/sda2 /mnt/mountpoint
           dmesg | tail  or so
           dmesg | tail  or so
           dmesg | tail  or so
    ~ # mdadm --stop /dev/md0 && mount -t ext5 /dev/sda2 /mnt/mountpoint
    mount: unknown filesystem type 'ext5'
    ~ # dmesg |tail
    md: md0 stopped.
    md: md0 stopped.
    md: md0 stopped.
    md: md0 stopped.
    md: md0 stopped.
  • Mijzelf
    Right. So sda2 doesn't contain a valid ext[12345] volume. (ext5 doesn't exist, AFAIK, and ext1 was called ext. Don't know if that is still supported. ext2 is old).
    Your first post on June 17 tells md0 contains an ext[234] filesystem, and your last post on June 18 tells sda2 is (the only) member of md0. So I must be mistaken in my assumption that the start of the partition is also the start of the filesystem.
    Can you post the output of
    mdadm --examine /dev/sd?2
    How old was the existing raid array, before you converted it?
  • Carlusha99
    Mijzelf:
    Here is the output:
    /dev/sda2:
              Magic : a92b4efc
            Version : 1.2
        Feature Map : 0x0
         Array UUID : fe6cce5e:c2787799:d330641f:892b916a
               Name : NSA325-v2:0  (local to host NSA325-v2)
      Creation Time : Sat Jun 15 10:49:19 2019
         Raid Level : raid1
       Raid Devices : 2
     Avail Dev Size : 976244928 (931.02 GiB 999.67 GB)
         Array Size : 976244792 (931.02 GiB 999.67 GB)
      Used Dev Size : 976244792 (931.02 GiB 999.67 GB)
        Data Offset : 2048 sectors
       Super Offset : 8 sectors
              State : clean
        Device UUID : 870f56e2:da90ec23:6f0b1722:abde0849
        Update Time : Mon Jun 17 19:52:15 2019
           Checksum : e934af94 - correct
             Events : 366
       Device Role : Active device 0
       Array State : A. ('A' == active, '.' == missing)
    /dev/sdb2:
              Magic : a92b4efc
            Version : 1.2
        Feature Map : 0x0
         Array UUID : 3cc8587e:22cbb2ab:fead2960:f311196e
               Name : NSA325-v2:1  (local to host NSA325-v2)
      Creation Time : Sat Jun 15 10:56:37 2019
         Raid Level : linear
       Raid Devices : 1
     Avail Dev Size : 1952996928 (1862.52 GiB 1999.87 GB)
      Used Dev Size : 0
              State : clean
        Device UUID : fc4704f1:da35344d:bef3f7f7:b2385146
        Update Time : Sat Jun 15 10:56:37 2019
           Checksum : 6a743ae0 - correct
             Events : 0
           Rounding : 0K
       Array State : A ('A' == active, '.' == missing)
    mdadm: cannot open /dev/sdc2: No such device or address
    mdadm: cannot open /dev/sdd2: No such device or address
    mdadm: cannot open /dev/sde2: No such device or address
    mdadm: cannot open /dev/sdf2: No such device or address
    mdadm: cannot open /dev/sdg2: No such device or address
    mdadm: cannot open /dev/sdh2: No such device or address
    mdadm: cannot open /dev/sdi2: No such device or address
    mdadm: cannot open /dev/sdj2: No such device or address
    mdadm: cannot open /dev/sdk2: No such device or address
    mdadm: cannot open /dev/sdl2: No such device or address
    mdadm: cannot open /dev/sdm2: No such device or address
    mdadm: cannot open /dev/sdn2: No such device or address
    mdadm: cannot open /dev/sdo2: No such device or address
    mdadm: cannot open /dev/sdp2: No such device or address
    mdadm: cannot open /dev/sdq2: No such device or address
    mdadm: cannot open /dev/sdr2: No such device or address
    mdadm: cannot open /dev/sds2: No such device or address
    mdadm: cannot open /dev/sdt2: No such device or address
    mdadm: cannot open /dev/sdu2: No such device or address
    mdadm: cannot open /dev/sdv2: No such device or address
    mdadm: cannot open /dev/sdw2: No such device or address
    mdadm: cannot open /dev/sdx2: No such device or address
    mdadm: cannot open /dev/sdy2: No such device or address
    mdadm: cannot open /dev/sdz2: No such device or address
    Before the conversion the NAS was only a one TB drive. I added another 2Tb drive and tried to convert the one TB Drive to Raid1.
  • Mijzelf
    <quote>Before the conversion the NAS was only a one TB drive. I added another 2Tb drive and tried to convert the one TB Drive to Raid1.</quote>
    But how old was it?
    Here you see an array of my 325:
    /dev/sda2:<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Magic : a92b4efc<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Version : 0.90.00<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; UUID : 3a22b091:bc91e802:3febb798:91bfbafd<br>&nbsp; Creation Time : Fri May&nbsp; 4 21:08:15 2012<br>&nbsp;&nbsp;&nbsp;&nbsp; Raid Level : linear<br>&nbsp;&nbsp; Raid Devices : 1<br>&nbsp; Total Devices : 1<br>Preferred Minor : 0<br><br>&nbsp;&nbsp;&nbsp; Update Time : Fri May&nbsp; 4 21:08:15 2012<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; State : active<br>&nbsp;Active Devices : 1<br>Working Devices : 1<br>&nbsp;Failed Devices : 0<br>&nbsp; Spare Devices : 0<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Checksum : 10d4ace4 - correct<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Events : 1<br><br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Rounding : 64K<br>
    As you can see it is created in 2012, andt uses metadata version 0.90.00, while your linear array sdb2, created in 2019, uses metadata version 1.2. So apparently ZyXEL switched default metadata version somewhere in this years.
    That matters, as you can read here. For 0.9 the header is at the end, and for 1.2 the header is at the start. So if the firmware converted an 0.9 linear array to an 1.2 raid1 array by simply re-creating the array, it has overwritten the start of the filesystem.
    I think that can be repaired, ext3/4 is quite a robust filesystem, but repairing a filesystem from an wrong assumed data start is not a good idea, of course.
    Do you have an extra (external?) harddisk of at least 1TB which could be used? In that case we could create a bit-by-bit copy of the disk from the start of the partition, and try to repair that, and if that fails create a copy from the current start of the filesystem, and try to repair that.
