Can't connect via multy app after power failure.
Elt
After a power failure my app will no longer connect to my multi. I've also had to replace my modem/router, as it failed. Nothing I've tried so far has worked. Will I have to set everything up from scratch again? Thanks
#MultyX_Jul_2019
#MultyX_Jul_2019
What happened with the power failure?
What color of your Multy glow?
Maybe you should try to factory reset your Multy instead.0
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
