NAS 326 printserver
Frani360
Hi
Hat jemand Erfahrung mit dem printserver vom NAS?
Ich würde gerne über meine Handy drucken, ich mache es über Printer Share, der Drucker wird auch erkannt aber er druckt nur 3 oder 4 zeilen,dann ist Schluss. Ich habe einen Kyocera Laserdrucker.
Gruß frani360
#NAS_Aug_2019
Gruß frani360
#NAS_Aug_2019
What is the model of your printer?
Translation by Google.
* the printer is also recognized but he prints only 3 or 4 lines, then it's over.
If you try to print the different document, does it also only print 3 or 4 lines?
I am having trouble getting the NAS236 print server to work. I can see the printer listed in control panel/service/print server but do not know how to direct a document to be printed via the print server. It says it is on-line in the NAS236 control panel/service/print server. In Windows 11/Add Printer/Printer Properties/Ports, what port do I select?0
You can check the compatible list on the zyxel page, maybe your printer is not compatible?
https://www.zyxel.com/products_services/2-Bay-Personal-Cloud-Storage-NAS326/compatibility
- 588 USG FLEX H Series
- 476 News and Release
