Data loss
lacc47
lacc47 Posts: 4 image  Freshman Member
edited August 2019 in Personal Cloud Storage
NAS326
I wanted to access my drives so I removed the drives from the nas. It is possible, that I took them back reversed, but It is not probable. Anyway, I cant access my drives. NAS turns off after boot beep. Without the drives it boots and it is accessible, but with the drives it turns always off. How can I repair this error?
There was no raid, it was two independent disk.
thanks
#NAS_Aug_2019
  • Mijzelf
    Mijzelf Posts: 3,074
    image  Guru Member
    It doesn't matter when you exchanged the disks. The disks are recognized by their raid header (which is also available on a single disk layout).
    Try the disks one by one. I think one of them died.
  • lacc47
    Many thanks for answer.
    I made factory reset without the disks, and after that the problem is solved, just I lost my configuration. Nas runs up, I can access the disks as befor.
    regards
