Aurora Cam notice of disconnection in the APP
pancho35m
since sunday i get just an email notification that something happened and i can see the three pictures but if i started the app i get the notification that my camera is offline.
I am using iOS
BR
Pancho
#Others_Aug_2019
I am using iOS
BR
Pancho
#Others_Aug_2019
Do you mean when you open Aurora App, the camera will show offline? Or ...
Can you share what is the firmware version of camera and App version?
And what is the LED status?0 -
Firmware is V1.00(ABEQ.3)C0
LED is turned off
The funny thing is email notification is working but if i want to connect to the camera via app the camera is offline yes
Have you try to reset and reinstall Aurora?
It seems not normal. I never meet this problem in my ZYXEL camera.
But what do you mean "i can see the three pictures"? Is it show on email notification?0 -
yes right it seems to be that the camera is still working because if an action takes care then i got an email notification. in this email notification there are three pictures of the event. that seems to be working fine.
I will do a reset on the camera and then i will check it again.
thanks for your help
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
