Plex.TV for NAS326??
so I did but I couldn't install plex, so I wanted help not to tell me how I should do it because I read the guide0
So be it.
so the problem remains, I followed the guide for nas326, why can't I install it?
Buongiorno a Tutti, è possibile avere una mano ad installare plex sul mio nas 326 ??1
Buongiorno ragazzi io ho un zyxel 326 vorrei inserire plex nelle app qualcuno può aiutarmi grazie mille.
hola me podeis decir como instalar plex en Zyxel Nas 326 o si hay tutoriales con inagenes o algo gracias0
hay alguien que alla puesto Emby0
Dear Mijzelf,Please check the photos below.I did everything which you said. But at the last step i cannot the plex tv app.Where is my mistake?ThanksPS: I have Nas3260
Don't know which instructions you are referring to. But web_prefix shouldn't have an extension. And the size doesn't fit either. The 'real one' is only 54 bytes.
Hi,I am trying to use exactly your way.I am entering the link which below your post.Than, I am passing the "NAS326" section, than "zypkg", than "5,21" (I thought, highest number is the updated one ), Than push to link " MetaRepository_20181001_arm_015.zpkg" to download it.After download, ı renamed it from "MetaRepository_20181001_arm_015.zpkg" to "web_prefix"For last step, I am creating a folder named "zy-pkgs" in main "admin" folder.That is all.Am I wrong ?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
