SFTP on NAS520
Josathome
I have my NAS behind a router w Tomato firmware. I like to be able to copy/open/edit/etc the files on my NAS (in my shares). Over secure connection.
1) if I enable SSH and FTP on the NAS and connect remotely using e.g. Filezilla, using SFTP option, is this then a secure SFTP connection?
2) I read that it is better to use (SHA?) keys to remotely connect to the NAS instead of password. How to do that? Do I need to install extra apps on the NAS?
3) The Tomato firmware on my router allows setting up SFTP and VPN connections. But these are connections to my router, not to the NAS behind it. Can I use this to securely connect to my NAS? As alternative to 1) and 2)?
you may have noticed it: i am no network expert, so any suggestions are welcome
#NAS_Aug_2019
#NAS_Aug_2019
Best Answers
As far as I know, SFTP only allow to use administrator account (admin or root) to login.
What I did as below:
1. Enable the services on ZYXEL NAS - FTP and SSH.
2. Set the port forward rule on router - External Port 2222 <-> Internal Port 22.
3. Using router's WAN IP + External Port to access ZYXEL NAS from outside via SFTP.
I found another way to you. I think this would be useful for your family members.
1. First, you need to download the WebDAV client, I'm using RaiDrive.
2. Enable the WebDAV services on NAS520.
3. Set the port forward rule on router - External Port 5003 <-> Internal Port 5003.
4. To configure router's WAN IP, External Port, NAS Folder Path and User Account on RaiDrive, then you can mount it as network drive on remote computer.
Please make sure the path must be "/webdav/sharedfoldername".0
Can you share what is your purpose?
Purpose is to allow my family members to remotely access and manage their data stored on the NAS meaning copy/paste/edit/move etc. “just as windows explorer”...0
Please make sure the path must be "/webdav/sharedfoldername".0 -
Mihawk, thx for the options. I will try both to see how they work for me. Webdav didn’t work well in the past, but I guess I did something wrong. I will therefore include your RaiDrive suggestion1
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
