Latency issues with Multy X
paulbutcher
I have a 2-node Multy X installation. It is generally behaving well, but I am having problems with latency spikes. Most of the time the latency is very low (approx 5ms) but occasionally (approx once every 5 minutes) the latency spikes to several hundred ms. This is causing problems when trying to use videoconferencing systems such as Zoom.
See the following screenshot from a latency monitoring tool https://peakhourapp.com
I would be vey grateful for suggestions about what might be causing this, and what I could do to address the problem.
Note - I am confident that the problem is with the Multy and not my internet connection for the following reasons:
#MultyX_Sep_2019
- I do not experience the problem when connecting directly to the Internet router provided by my ISP.
- My ISP (Andrews & Arnold) provides constant connection monitoring (Firebrick), and this shows no problems with the connection.
#MultyX_Sep_2019
Hi @paulbutcher,
Please click "Send Feedback" on Multy App, and we will analyze the log file.
Thank you.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
