Entware-ng install error on NSA325v2
The simple fact that I wrote a package to install Entware-ng on a ZyXEL, doesn't make me an expert of all provided Entware-ng packages, of course.The only sane answer I can give you is that the firmware won't use your Entware-ng php packages, as they are on the wrong place. (in /opt/bin/, I think, while the firmware uses /usr/local/zy-pkg/bin/). So if you want to use php7, you'll have to install your own webserver either.MariaDB is another story, as it will conflict with MySQL (same socket). So to use it you'll have to use a non-standard socket (no idea how), or uninstall/disable the php/MySQL zypkg.1
OK, thanks for all your help, I can now have a look the uipgrades.
Cheers0 -
Sorry, I thought I had posted a reply. Thank you very much Mijzelf for your help. I'm back up and running, I'll look at getting the other stuff running.
Thanks again! You're a star0 -
You did. But somehow you also marked it as 'Accepted answer', and that's enough reason for this stupid forum to change the sequence of the posts.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
