!!!!!!!!!!!!!!!!! ATTENTION !!!!!!!!!!!!!
this will install a second mysql in the /opt folder
NAS540: Update of MySQL?
JockeSve
Is there a way to update MySQL version from current (5.1.73) to more up to date(like 5.7) or even to MariaDB 10.2 (or newer)?
#NAS_Feb_2019
#NAS_Feb_2019
Hi, I've been looking for something similar as I want to convert the MySQL tables to InnoDB which isn't possible with hte old version of MySQL (5.1.73 and InnoDB support came in at v5.5+).
Anyone know if this can be done?0 -
As Zyxel seems to have abandoned all support of 540 entirely the chance is minimal that the update is coming, like ever.
I don't have any idea of on what level the 542 runs, but if that's newer: maybe (hopefully!) someone with skills could port that package to 540 as well...0 -
Ok after days of work i finally get MySQL in version 5.7 running. Here are the steps i really don't know any more what i have to install but the logs will tell you.
- First you need to install Entware how To you find here https://github.com/Entware/Entware/wiki/Install-on-Zyxel-NAS542
- Add /opt/bin and /opt/sbin to the path
- Then you need to install CMake from Source https://github.com/Entware/Entware-ng/issues/672 ATTENTION: you have to adjust the prefix to /opt
- Then you need the git clone of the mysql-server https://github.com/mysql/mysql-server/tree/5.7
- Then you need to create a folder "bld" in the clone and cd in it
- Then you need to generate the cmake files this you do the following
cmake .. -DDOWNLOAD_BOOST=1 -DWITH_BOOST=1 -DCMAKE_INSTALL_PREFIX=/opt - After it is succesfully finished you have to enter the following:
cmake --build . --target install --config release
I recommend to do that only if you a fluent in linux commands and cmake building.
PS: I takes a lot of time for the cmake commands so i recommend to setup screen over entware and to run the commands in an screen session that is detachable
Well, thanks but my skills doesn't pass following requirement:I recommend to do that only if you a fluent in linux commands and cmake building.
I've almost giving up the Zyxel MySQL feature due to poor/non-existent updates and running it with RPi4 together with PiHole.
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 462 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
