Zyxel NAS542 - copied files from old NAS are inaccessible (open from NAS share)
            tried one more option:
chown-nobody -hR USER:everyone * from main share/ folder
have no more idea's on my own
            How about the smb.conf settings from that specific share?
            I have posted it 3 posts earlier (old smb, new smb for SHARE) and 2 posts earlier (old smb, new smb for GLOBAL)How about the smb.conf settings from that specific share?
</code>zyxel /etc/samba/smb.conf</pre><div></div><pre class="CodeBlock"><code><div>[share]</div><div>        path = /i-data/12344321/share</div><div>        follow symlinks = yes</div><div>        strict allocate = yes</div><div>        allocation roundup size = 0</div><div>        aio write size = 4096</div><div>        comment = "share"</div><div>        browseable = yes</div><div>        valid users = "admin" "pc-guest" "xxx1" "XXX" "+everyone" "+XXX"</div><div>        guest ok = yes</div>
            Ah sorry, missed that post. Well, after looking at the files, the most probable difference I can find is oplocks. That's a Windows way to lock files, to prevent multiple edit sessions at a time. I can imagine some editors just refuse to work if they can't get exclusive accessIn old file we have
<div>[global]</div><div><br></div><div>oplocks = yes</div>
in new file it's<div>[global]</div><div><br></div><div><div>kernel oplocks = no</div><div><br></div>level2 oplocks = no</div>
(I'm very happy that smb.conf always have simple, not confusing options)So try to edit the latter to 'yes', and restart samba.<div>/etc/init.d/samba.sh restart<br></div>
            Thx for help, looks like everything is fine now... hope it will stay that way
 not sure if chown-nobody was the solution or changing oplocks
            You will know after the first reboot. The edit in smb.conf won't survive a reboot, nor will it survive any change in samba configuration using the webinterface.Basically smb.conf is generated dynamically by the NAS' backend.0
            New problem - old files are accessible, but files created later (totally new files) are inacessible... this is starting to be quite annoying
            What's the difference in ownership/permission for an old and a new file?
            MijzelfWhat's the difference in ownership/permission for an old and a new file?if you are refering to
ls -alh
it is the same as before...0 -
            Maybe the file is (still) locked? smbstatus can tell.
 - 439 Beta Program
 - 2.8K Nebula
 - 200 Nebula Ideas
 - 6.3K Security
 - 499 USG FLEX H Series
 - 323 Security Ideas
 - 49 Wireless Ideas
 - 287 Service & License
 - 457 News and Release
 - 89 Security Advisories
 - 4.3K FAQ
 - 96 Security Highlight
