About seeding torrents on NSA310S - without download it
stefan4o
I have a NSA310S, I`m trying to seed a created torrent by Utorrent from my local folder. But when I load it in Download Service nothing is happened. Just stays at 0.0% and nothing... When I did the same thing and open the created torrent in Utorrent on my notebook, everything is OK, the status of Complete is 100% and can seed it. Is there any cure about it? I don`t want my notebook be turned ON all day long.
Regards
#NAS_Nov_2019
Regards
#NAS_Nov_2019
Does every torrents meet the same problem?
Do you use "Download Service" to download torrent? How about "Transmission"?
If it still does not work, try to reset NSA310s.0 -
I have the nsa310s a week ago. I've it reseted and ready to work with. Aint touch almost anything on it.0
I have similar problem, Transmission is working fine, download service is not working at all. What should i do?0
I think I have a decision. It`s not that simple but it WORKS. So you need to do following steps:
1. Create and seed the torrent in PC - the torrent-client will immediately seed it
2. Download or just load the same torrent file in Download Server.
3. Let the client download your own torrent and next - it will seed it as long as need (you can change the time to "unlimited")
It works for me !!!1 -
Here`s the easy steps:
1. Download and install Utorrent (it is free)
2. Start the .exe
3. Click on File=>Create New Torrent
4. The program will ask you to Select Source
a. Select a single file with Add File
b. Select a folder with Add Folder
5. Check the option Start Seeding (it is enabled by default)
6. Click the Create button
Meanwhile you will be asked to save a torrent file in your PC directory. Dont stop the Utorrent or PC until the NSA app take the all torrent in 100%.
After this steps go to your NSA in the Download Server.
Add=>Torrent File =>Load the torrent file you`ve created earlier on your PC
The NSA will start to download it immediately, just wait to take it on 100%. After that it will automatically seed (in the Preferences you can go to P2P Download section and check the box Or seeding time is, place 0 in the field (means that will seed until erase it).
Hope it helps.1
- 588 USG FLEX H Series
- 476 News and Release
