AIshield on Multy Plus seems to be blocking Windows 10 update downloads
Ashenshugar
I have recently installed a Multy Plus mesh WiFi network and activated the AIshield license, however it appears to be blocking downloads from windows 10 update on my PCs.
If I inactivate the intrusion prevention system in the AIshield phone app the download completes successfully on a restart of the PC.
I have not set up any profiles or added any site to the forbidden or trusted lists.
Does anyone know how I can configure AIshield to allow traffic from Windows Update Servers?
#MultyPlus_Nov_2019
#MultyPlus_Nov_2019
Hi @Ashenshugar,
In order to provide you with better assistance, we have contacted you via private message. Please kindly check your message box.0 -
Hi @Ashenshugar ,
After our investigate, the IPS does block the Win10 upgrade server, we will fix this issue on next IPS signature data update.
If there is a similar issue that happened in the feature, please add the threat IP/Link to the trusted list.
Please follow the below steps to add it into the trusted list, it can allow the IP/Link pass-through the AiShield.
Best Regards,
Eric0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
