setup 520 new password after login 1234
digitower
digitower Posts: 1
edited December 2019 in Personal Cloud Storage
having a NAS520, resetted all want to start setting up everything
i log in with admin and 1234 the i have to make my own pasword.
i made one with number, special signs an alfnumeric  for example Secrets01#
when i enter this twice. it says before 1 press submit (password not acording to rules )
What do i wrong?
#NAS_Dec_2019
  • Mel
    Mel Posts: 83 image  Ally Member
    Tested the password Secrets01# and it works in my side.
    After you set the password Secrets01#, do you able to login NAS520 via the new password?
    Can you share the screenshots about this problem?
    You can try another way to change the password.
    Go to Control Panel > Privilege and Sharing > Users, tap admin account and edit it.
