HELP! NAS540 constantly beeps
L4z33w
L4z33w Posts: 9  Freshman Member
Second Anniversary
edited January 2020 in Personal Cloud Storage
Hello, I need help with an NAS540.
After I had disconnect one HD while booting, the NAS doesn't boot anymore.
When I start it up, it starts to beep constantly. I cannot do anything, there is now way to restore the defaults.
How can I rescue this NAS?
Please help me.
best regards
#NAS_Jan_2020
«1
  • Mijzelf
    Mijzelf Posts: 2,918  Guru Member
    Does it also beep if you start it without disks?
  • L4z33w
    Second Anniversary
    @Mijzelf
    Yes, it beeps everytime, with or without disks
  • Mijzelf
    That could be a damaged flash. Reflashing might help. I should have a flashing script for the 5xx somewhere, give me some time to search for it.
  • L4z33w
    Second Anniversary
    @Mijzelf
    Oh that would be nice!!! Take your time & thank you!
  • L4z33w
    Second Anniversary
    edited January 2020
    @Mijzelf
    You made my day! Many many thanks!
    the usb stick worked well, after flashing it runs now without beeps.
    Greetings
  • SYUNG61
    SYUNG61 Posts: 2  Freshman Member
    Hi, I have exactly the same issue but after flashing my NAS540 the hard drives lights were off. I have no access to the NAS any more. Please help.
  • Mijzelf
    Have you already tried a factory reset? Press the reset button on the back until it has beeped 3 times (+/- 15 seconds)
  • SYUNG61
    The reset button no longer works as well. There is no beeping sound at all with or without the drives.
  • Mijzelf
    If the box doesn't noticeable boot, and the reset button doesn't work, the only way (AFAIK) to do something useful is hooking up the serial port. Here I have written something about it. Note: the serial port is not rs232, but TTL 3.3Volt. Hooking up a rs232 connection will possibly fry the CPU.
