NBG6515 bricked after firmware upgrade.
Hello,I have a similar problem after firmware upgrade with my NGB6716, only the Power led is on and have tried the reset procedures mentioned, but no success.Please help me, thanks.0
Hi emn_svs,
Please refer to my article.
https://homeforum.zyxel.com/discussion/comment/2217#Comment_2217
Hello.
Same problem, router did’t boots up after firmware upgrade to the latest version.
It is impossible to connect to the router via LAN or FiWi.
Is there any solution for this problem?
@Plyt,
What is the model name of your router? NBG6515?
Do you try to reset it? Does the problem still exist?
As far as I know, there is no firmware recover way for NBG6515.
I think you should directly contact your local Zyxel support.If your region is EU, you can contact them online via the link (https://support.zyxel.eu/hc/de/requests/new).
@Zyxel_Kelly
I have the same issue for NBG6716 Model Number0 -
Please I have same issue, my Zyxel nbg6515 is bricked, only the power led comes on. Please help me to resolve this. Gidboat@gmail.com
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
