Low Backhaul on AC3000 Multy
AMDB9
The backhaul between my two AC3000's is only 288mbps transfer rate. I thought I would get something over 1000. The Multy App says the locations are optimal. Is there any chance I have messed the settings?
#MultyX_Jan_2020
#MultyX_Jan_2020
Dear Sir,
1.The location detection is according to the signal from each Multy, but the throughput between two nodes will be affected by the environment, and that affection may cause by the wall, ceiling, signal interference, distance, etc.
2. Is it possible to share the Diagnose result of your Multy App?
3. May I know the throughput from the internet to the second node?
- 602 USG FLEX H Series
- 480 News and Release
