HTTPS and Certificate
Markus
Hi there,
I think I need your help:
I configure a little with the connection "HTTPS only" and the certification and now I do not get access to the web interface.
Is there a way to disable HTTPS and use normal HTTP using SSH command?
Nas520
Thanks for your help!
#NAS_Feb_2020
#NAS_Feb_2020
Thank you!But is there any other way? The reset is my final option. I configured the Nas with many share folders and dns etc.
I even create an new certificate with ssh but the browser ignore it.0 -
Maybe. If you are a bit into Apache. The webinterface runs on Apache, and I *think* HTTPS only is forced by some redirect rule.If you remove that redirect rule and restart the webinterface, it might work.The config file for the main webinterface is /etc/service_conf/httpd.conf. You can reload the webinterface by/etc/init.d/httpd.sh reloadDon't worry to screw things up. The apache configuration is completely in ram, and is rebuild on boot.1
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
