HTTPS and Certificate
Markus
Markus Posts: 2 image  Freshman Member
edited February 2020 in Personal Cloud Storage
Hi there,
  I think I need your help:
  I configure a little with the connection "HTTPS only" and the certification and now I do not get access to the web interface.
  Is there a way to disable HTTPS and use normal HTTP using SSH command?
  Nas520
  Thanks for your help!
#NAS_Feb_2020
  • Batou
    Batou Posts: 101 image  Ally Member
  • Markus
    Thank you!
    But is there any other way? The reset is my final option. I configured the Nas with many share folders and dns etc.
    I even create an new certificate with ssh but the browser ignore it.
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    Maybe. If you are a bit into Apache. The webinterface runs on Apache, and I *think* HTTPS only is forced by some redirect rule.
    If you remove that redirect rule and restart the webinterface, it might work.
    The config file for the main webinterface is /etc/service_conf/httpd.conf. You can reload the webinterface by
    /etc/init.d/httpd.sh reload
    Don't worry to screw things up. The apache configuration is completely in ram, and is rebuild on boot.
