No signal detected on node 2 during “Location check” - what to do?
TCordth
I have installed node 1 of a Zyxel Multy U succesfully. When I add node 2 i get the following issue. I get all the way to the step where node 1 and 2 are synced, but when i get to the “Check location” step it never detects a signal and i am not able to finish the installation. I have tried with factory reset but I always get stucked in
this step. I have also tried to move the two nodes close to each other without any luck. Have any of you experienced this problem and what is the solution?
#MultyU_Feb_2020
#MultyU_Feb_2020
Have you tried to switch the primary Multy and second Multy?
You can install the second Multy as the Primary Multy, then add the other Multy.
The switch solved the problem, thanks!!!0
- 588 USG FLEX H Series
- 477 News and Release
