Is it possible to mount another NAS to my existing one?
AleXSR700
I would like to add a mount to my second NSA325v2.
I tried
Is there a way to do this? I know it is possible to backup data to another NAS via the webUI. But it must also be possible to create a direct link so I can copy files via the command line to the second NAS.
Anybody have any ideas?
The second NAS is currently an NFS share but can also be accessed by Windows, so also works as a Samba share.
#NAS_Feb_2020
I tried
root@NSA325-v2-101:/ffp# mount -t cifs //192.168.0.10/BackMisc_nfs/BackMisc_nfs/path path
mount: wrong fs type, bad option, bad superblock on //192.168.0.102/BackDownMisc_nfs/BackDownMisc_nfs/pahe,
missing codepage or helper program, or other error
(for several filesystems (e.g. nfs, cifs) you might
need a /sbin/mount.<type> helper program)
In some cases useful info is found in syslog - try
dmesg | tail or so
#NAS_Feb_2020
Hi, I do not know what exactly you would like to copy, but you can ssh / ftp to the other NAS for sure from mc, and then you can do the copy. If you would like to automate some backup in cron this is not a solution, or you should write some script for access start copy - this is much far from my basic knowledge.0
I have never tried this, but I think an NFS mount should be possible:mount //192.168.0.10:/path/to/nfs/share mountpointYou should be able to see the full pathnames withshowmount --all 192.168.0.10For cifs you need the cifs kernel module. I can't remember if it's available in the kernel module package for ffp which I provided years ago. And maybe you'll need a special mount binary, as your error suggests.A third option is sshfs, which runs on top of fuse. You'll need the binary, which might be available in ffp or entware-ng.sshfs 192.168.0.10:/i-data/sysvol/share pathUnmount withfusermount -u pathA problem with this is that it uses encryption, which limits the speed to about 1MB/sec.
- 588 USG FLEX H Series
- 477 News and Release
