NSA325 V1 BackupPlanner
Raffe51
Hi
I got a NSA325 V1 and cannot install the BackupPlanner from the PackageManagement
Do anyone know why?
#NAS_Feb_2020
Do anyone know why?
#NAS_Feb_2020
The Problem is solved. Had to install a new Metarepository, a new web_prefix file.
After that I could get a new Packagelist and had no problem to install thr BackupPlanner.0
It stops at 25%. I have restarted the NAS. No change0
Is there any message pop-up after click "Retrieve List From Internet"?
How about other packages? Can you able to install others?0 -
Thank you Penny for answering.
Yeas, I can install other packages. I did install pyLoad without problems.
There are no messages after I done a "Retrieve List From Internet". It just open a pop-up windows, but will not find any new packages.It says prograss 0% and then disapears after some seconds.
I did attach a file with the picture of my packages.
I am using NSA325_4.81(AAAJ.1)0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
