Arp Spoofing - Multy X
MIBSWE
I have a device called FIng box, which allows me to block devices on the network via a scheduler. It doesn't work. Their answer was "Incompatible Router – Fingbox pauses Internet using a technique called ARP spoofing. Some routers contain software designed to block ARP spoofing, so prevent Fingbox performing this feature."
Does Multy X routers block ARP spoofing? If it does, is it possible to disable?
Thanks in advance.
Regards,
MIBSWE
#MultyX_Mar_2020
Thanks in advance.
Regards,
MIBSWE
#MultyX_Mar_2020
Dear Sir,
Yes, Multy does block ARP Spoofing, and it doesn't have a switch to disable it.
Best regards,
Eric0
Dear Sir,
Best regards,
Eric0 -
Thank you Eric for your quick reply.0
- 588 USG FLEX H Series
- 477 News and Release
