NAS 326 lack of access
speed
Mam serwer NAS326 działał dobrze, ale po włączeniu wczoraj jest widoczny w sieci, ale nie ma danych w folderze, ponadto nie mogę się zalogować przez stronę, tylko dostęp za pośrednictwem ssh działa
czy jest jakiś sposób, aby działał bez utraty danych?wersja oprogramowania firmowego v5,21 (AAZF.5)
#NAS_Mar_2020
#NAS_Mar_2020
Do you mean SSH can login, but not able to login web interface of your NAS326 with the same account? Do you upgrade your NAS326?
Is there any screenshots about the firmware version and the problem you encountered?
Here is the FAQ for your reference.
https://homeforum.zyxel.com/discussion/3370/faq-upgrading-latest-nas-remote-code-execution-vulnerability-firmware#latest
Yes i can log in via ssh,not web interfaceI did not update the software,currently there is the version 5,21 (AAZF.5)I don't know where and how to check for errors
Nothing happens during the reset one beep,apart from changing the password to default0 -
Do you mean that you cannot access web interface after reset password? But still can access via SSH?
Have you tried to access NAS via incognito window?
What is the error message from your browser? can you provide the screenshot?0 -
Nothing happens during the reset one beep,apart from changing the password to defaultDo you mean that you cannot access web interface after reset password? But still can access via SSH?Yes,i can login ssh not web interfaceHave you tried to access NAS via incognito window?What is the error message from your browser? can you provide the screenshot?When logging in via the web, I am constantly trying to log in infinitely,there are no errorsI tried Chrome, Internet Explorer. Firefox with incognito mode also to no avail
You may try to reset your NAS326. P.S. Reset would not remove your data.0
Hello after a long timeNas after a few attempts to launch, it loaded normally,and has been acted stable,but until nowAfter starting today, the problem has returnedNo access to files and web interface except only sshReset gives nothingMaybe some ideas?0
Try to factory-reset to clear all settings.
And re-configure the setting you want.
After factory-reset in the web panel i am shown this message
After clicking OK it takes me to this window and so it goes load and load...infinity
Is it the fault of any of the disks?
However, after a long loading time managed tounfortunately it looks somehow wrong with the raid systemIs it possible to restore or rebuild no data loss the whole system somehow?HDD status is good
Have you checked the detail information for HDD in SMART? or could you provide the screenshot the the detail information for HDD in SMART?
- 588 USG FLEX H Series
- 476 News and Release
