NAS 326 lack of access
speed
speed Posts: 7 image  Freshman Member
edited March 2020 in Personal Cloud Storage
Mam serwer NAS326 działał dobrze, ale po włączeniu wczoraj jest widoczny w sieci, ale nie ma danych w folderze, ponadto nie mogę się zalogować przez stronę, tylko dostęp za pośrednictwem ssh działa
czy jest jakiś sposób, aby działał bez utraty danych?
wersja oprogramowania firmowego v5,21 (AAZF.5)
#NAS_Mar_2020
«1
  • eozrocwd
    eozrocwd Posts: 58 image  Ally Member
    Do you mean SSH can login, but not able to login web interface of your NAS326 with the same account? Do you upgrade your NAS326?
    Is there any screenshots about the firmware version and the problem you encountered?
    Here is the FAQ for your reference.
    https://homeforum.zyxel.com/discussion/3370/faq-upgrading-latest-nas-remote-code-execution-vulnerability-firmware#latest
  • speed
    edited March 2020
    Yes i can log in via ssh,not web interface
    I did not update the software,currently there is the version 5,21 (AAZF.5)
    I don't know where and how to check for errors
    Nothing happens during the reset one beep,apart from changing the password to default
  • PeterK
    PeterK Posts: 38 image  Freshman Member
    edited March 2020
    Do you mean that you cannot access web interface after reset password? But still can access via SSH?
    Have you tried to access NAS via incognito window?
    What is the error message from your browser? can you provide the screenshot?
  • speed
    Yes,i can login ssh not web interface
    When logging in via the web, I am constantly trying to log in infinitely,there are no errors
    I tried Chrome, Internet Explorer. Firefox with incognito mode also to no avail
  • lodiabai
    lodiabai Posts: 120 image  Ally Member
    edited March 2020
    You may try to reset your NAS326. P.S. Reset would not remove your data.
  • speed
    Hello after a long time
    Nas after a few attempts to launch, it loaded normally,and has been acted stable,but until now
    After starting today, the problem has returned
    No access to files and web interface except only ssh
    Reset gives nothing
    Maybe some ideas?
  • Penny
    Penny Posts: 65 image  Ally Member
    Try to factory-reset to clear all settings.
    And re-configure the setting you want.
  • speed
    After factory-reset in the web panel i am shown this message
    After clicking OK it takes me to this window and so it goes load and load...infinity
    Is it the fault of any of the disks?
  • speed
    However, after a long loading time managed to
    unfortunately it looks somehow wrong with the raid system
    Is it possible to restore or rebuild no data loss the whole system somehow?
    HDD status is good
  • Mel
    Mel Posts: 83 image  Ally Member
    Have you checked the detail information for HDD in SMART? or could you provide the screenshot the the detail information for HDD in SMART?
