NAS 542 Twonky Server not reachable via 9001 port
frameworker
After resetting the NAS, I cannot reach port 9001 despite twonky is enabled via checkbox.
As I can remember there was no need to start twonky. Any mp3 or video files uploaded to the share "music" was accessible via any external device, e.g. an radio capable to stream via UPNP(?). WIndows 10 looks for the NAS542 share and found every media file on it.
But now, nothing works. Itunes option works.
I have checked/unchecked the twonky option several times, plus restarting the NAS, but with no success.
Any help appreciate!
#NAS_April
#NAS_April
Are you possible to access your twonky setting page?
If possible, please try to do rescan for all media file, here for you reference: https://homeforum.zyxel.com/discussion/584/no-files-or-media-visible-in-music-photo-video/p1
I'm having this issue. When I try to access #:9001 the browser says the page cannot be reached.
Can you check its port number?
You can check it on Windows. (NAS -> Properties)
Is it port 9001 or 9000 or ...? If it still not works, try reset NAS. (About reset, it doesn't affect data.)
Same here0
Hi @sitro
I've private message to get more information to clarify this case, please check the message box.0 -
I recall having a similar issue with my 326 a while back. The solution was to change the name of the nas itself and twonky server name.
I still don't know why that fixed it, I can only share what I experienced.0 -
ok just reply to Jerry in privateThe port 9001 is not open .nmap result on NAS :$ nmap 192.168.1.101
Starting Nmap 7.80 ( https://nmap.org ) at 2022-12-09 16:06 CET
Nmap scan report for nas.home (192.168.1.101)
Host is up (0.00027s latency).
Not shown: 984 closed ports
PORT STATE SERVICE
22/tcp open ssh
23/tcp open telnet
80/tcp open http
111/tcp open rpcbind
139/tcp open netbios-ssn
445/tcp open microsoft-ds
514/tcp open shell
548/tcp open afp
667/tcp open disclose
873/tcp open rsync
2049/tcp open nfs
5000/tcp open upnp
5001/tcp open commplex-link
8082/tcp open blackice-alerts
9000/tcp open cslistener
9090/tcp open zeus-admin
Nmap done: 1 IP address (1 host up) scanned in 0.08 seconds
Hi @sitro
After check the configuration of the twonky server, the port has been changed.
if you need to change the port back to 9001, you can use winscp to get the file from the NAS and after modify it, and then put the file back.
Before modified it, please always copy a original file before doing any action on it.
Hi @@sitro
I have import your twonlyserver.ini configuration in our local lab NAS.
But the issue do not occur.
As we use the nmap to do check of the NAS, the 9001 port should be opened when the twonkyserver is enabled.
To check if the NAS is running twonkyserver, you can check the command :lsof -i -P -n
Or use ps w | grep twon
And I would like to know how do you do to reset your NAS , after done the reset, the NAS set to default settings, it should work without any problem.
Best Regards,
Jerry
- 300 Beta Program
- 1.9K Nebula
- 103 Nebula Ideas
- 72 Nebula Status and Incidents
- 4.8K Security
- 4 USG FLEX H Series
- 242 Security Ideas
- 1.1K Switch
- 54 Switch Ideas
- 807 WirelessLAN
- 29 WLAN Ideas
- 5.5K Consumer Product
- 178 Service & License
- 309 News and Release
- 69 Security Advisories
- 19 Education Center
- 1.3K FAQ
- 556 Nebula FAQ
- 349 Security FAQ
- 118 Switch FAQ
- 147 WirelessLAN FAQ
- 33 Consumer Product FAQ
- 114 Service & License FAQ
- 70 About Community
- 56 Security Highlight
