LTE4506-M606 has to reboot every day? why?
jjer
I have bought this router, and it stops loading / loading without reaching every day, and i have to reboot. again. sometimes several times a day. My service is all right my hardware is all right and my software is all right. I found on Zyxels router homepage this : DHCP server -> "Lease 1440 minutes"? is it there the problem is? my connection has no limits. My GB use has no limits. Looking forward to an answer.
Hi jjer , on LTE4506 homepage the "DHCP server -> Lease 1440 minutes" this is the the amount of time a network device(such as your PC) can use an IP Address from LTE4506. The IP Address is reserved for that device until the reservation expires. Could you please describe the symptom of the problem you met more specifically then we could help more for this? For example, cannot access LTE4506 web GUI or LAN clients unable access Internet? Thank you.
Every thing seems fine, lights are green on the router, my mac wifi is green, I see the rooter on the wifi list, but the pages do not load, and loading times out. I get that this or this site cannot be reached. Those are not special nor "dangerous" sites - and i use them every day. I have to reboot though and then it works. I made a reset when sommer-time came, as the connections was completely gone there. But otherwise, daily reboot(s) to be on.1
"1440 minutes this is the the amount of time a network device(such as your PC) can use an IP Address from LTE4506. The IP Address is reserved for that device until the reservation expires."
- I don't understand that...0 -
Hi jjer , let me explain again for "DHCP server -> Lease 1440 minutes" , the lease time(minutes) specify how long(in minutes) each computer can use the information(especially the IP address) before it has to request the information again.Could you please take a screen video for the problem that show us what the situation you met?Thank you.0
There is nothing to see really, I am on a site, it has to reload, after a longer break and it just waits/tries to reload, at last my browser says "this site can't be reached". That's it, and I have to make a reboot on the zyxel page 192.1..... and it works again.0
Hi jjer , please help follow below instructions to check your device.1)Does your LTE4506 use the latest FW 1.00(ABDO.4)C0?2)Check if your LTE4506 enable the Packet Data Limit Setting, then un-ticked data limit setting to see if improve the problem.
3)Once the problem happen again, check the Internet Status if LTE4506 get IP address or not, and check the Connection Time too.
4)Apply Internet setting to reconnect the LTE WAN again. Before press Apply button, change the mode to Auto or 4G.
Hi, I have the same problem. When I some time is not active on the internet my device stop browsing on the internet as well. Only solution is reboot router. After rebooted router internet browsing works without problem. This issue happend once or twice a day.
@jjer did find any a solution or did change for another router?
thanks for your answer and advice
- 588 USG FLEX H Series
- 476 News and Release
