during the firmware upgrade the nas326 is stuck
perdidohate
During the latest firmware upgrade (NAS326_V5.21(AAZF.8)C0) it starts and at 10 % it doesn't go further . It's 3 hours now in the process. If i go to the panel, which is extremely slow, i can see that the cpu usage is 100% and if i try to restart, reset i receive a message like "cannot, doing firmware upgrade ".
the system led is solid white (so theoretically the firmware update has finished) but i cannot power the nas off with the power button.
I do not have plug the power off because i'm afraid of damage. What can i do?
I have found a similar post in the forum and after rebooting NAS the firmware upgrade can be completed.
You can check it
https://homeforum.zyxel.com/discussion/comment/8475#Comment_8475
You may have to press the button until one "beep" to reset. Have you tried that?0
You can check it
Reset doesn't work.Now i 've the same message like the one pointed by Kim so I've posted a question in the other answer. Thank you very much0
ok, i've turn it off and turn it on again. It was sitting for about 12 hours with the phrase "no log in.firmware update ongoing" when i try to log in. No firmware update but it's working again. No data loss. i'll just wait until my heartbeat returns normal to retry the update
Thanks everyone
Firmware update trouble. It's still updating after over 12 hours. I logged in to my NAS326 yesterday and was prompted to update my firmware. I chose to update it, and it only progressed to 10% complete after a couple hours, then no further progression. I closed my browser but I can no longer see any progression status. It only shows that a firmware update is in progress and I can't progress until the update is complete. I can still access the files stored, but it's extremely slow.
You can ssh into the nas and type command "top", you can see which process is running and occupy the most source.
Upgrade the firmware from V5.21(AAZF.10) to V5.21(AAZF.12) does not take me more than 5 miutues.
I think that might have something wrong in your network.0 -
Kim said:I have found a similar post in the forum and after rebooting NAS the firmware upgrade can be completed.
You can check it
I think this is the article they're saying
https://community.zyxel.com/en/discussion/7316/cant-log-in-web-admin-nas326-firmware-update-hung
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
