Configuring L2TP VPN on LTE7410-A214 Router
jonespr1
Hi
I have a LTE7410-A214 router and am experiencing some issues, as my mobile carrier uses commercial grade NAT which affects some of the devices in my house i.e. my Nintendo Switch cannot connect to others for remote game playing. I have an account with PureVPN for a static IP, which I believe will resolve this issue and want to configure the L2TP tunnel on the router.
I have configured in the Security -> L2TP VPN screen, but when I run a trace the traffic is not using that route and I see no way of verifying config in the logs.
I think I need to setup some type of routing to use VPN, but cannot understand from manual how to do this, I ideally want all traffic to take this route.
Robert
As the same as you, trying to search it's all IPSEC. If someone could share where could find the pure l2tp it will be more helpful.0
LTE7410-A214 support pure L2TP VPN not L2TP over IPSec. Enable the default route in Security>L2TP VPN> Default Route, when run the trace the traffic will use the route.
Where would I get one of those, tried googling, all seem IPSEC?0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
