web interface for multy x ac3000
Gerrit
is there a way to configure the Multy X AC3000 by web interface?
the huge advantage is that you can configure the Multy X AC3000 for ever and not depending on the app
#Multy_May_2020
#Multy_May_2020
Dear Sir,
Multy X only supports App management.
If you prefer to manage Multy via the Web interface, Multy Plus will be what you need.
Multy Plus supports Web GUI.
Please refer to the link for Multy Plus:
https://www.zyxel.com/products_services/AC3000-Tri-Band-WiFi-System-Multy-Plus/
Best Regards,
Eric0 -
Dear support,can you explain the logic of having only "app management" please?User case: if something configured wrong, that you've got no WIFI and the only way you have to reset completely the device.My Zyxel Multy U becomes a brick if I activate "Bridge mode", and that's quite easy to do, for there's no confirmation for this action.Thank you.Best regards,Yury
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
