Need help installing 4.70 firmware to NSA320
2»
  • seiji_k
    seiji_k Posts: 9 image  Freshman Member
    Thanks to your help, I'm now able to revive my NSA320!
    For the benefit of others who might ran into the same situation as me, I've outlined what I did:
    1. Did a factory reset of the NAS
    2. Used rescue stick image containing 4.50 firmware to boot the NAS
    3. Using the web interface, I upgraded the firmware to 4.70, which I downloaded from Softpedia
    4. After the firmware upgrade, I created a fresh volume using the web interface
    5. Using a FTP client, downloaded the 4.70 packages
    6. Copied the packages to the admin \ zy-pkgs folder share
    From then on, I'm able to configure the NAS and install packages.
  • pepev82
    pepev82 Posts: 3 image  Freshman Member
    Dear all,
    I need some help to fix my NSA-320 device.
    Sympton: cold start with power button: all led's are lights up and standstill, 2-3 sec later fan is start then another 3-4 sec and there is activity on the LAN conector but can not see on the network.
    Is there any idea about this fault? Hardware or software issue?
    I tried download the above rescue disk, but link are not working, and can not find any cached site on the web.
    May i get a copy of that usb image, please ?
    Many thanks in advance. Any help is much more than appreciated.
    Peter
  • Mijzelf
    Mijzelf Posts: 3,052 image  Guru Member
    https://zyxel.ddnss.eu/Users/Mijzelf/RescueSticks/
