2 ethernet ports on Nas 520?
atopos
atopos Posts: 2 image  Freshman Member
edited May 2020 in Personal Cloud Storage
I am trying to connect 2 pc's through ethernet on the 520,
both ports work fine on the 520(gigabit speed-orange led) but as soon as I connect the second port I do not have access to my files?
P.s I find it hard to believe that the 2 ethernet inputs are only for aggregated link..?
When connected to a 4 port 10/100 switch that I had laying around both pc worked fine but really slow.
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Lan1:
    IP->192.168.10.1
    Netmask->255.255.255.0
    Pc1:
    IP->192.168.10.2
    Lan2:
    IP->192.168.11.1
    Pc2:
    IP->192.168.11.2
    Gateway and dns are all empty. If your wifi happens to have one of these subnets (192.168.10.x or 192.168.11.x) use 192.168.12.x instead. Doesn't matter where.
  • Sakura_T
    Sakura_T Posts: 101 image  Ally Member
    You have to set interface for each ethernet port, they'll become a LAG if you assign the same configuration to them.
  • eozrocwd
    eozrocwd Posts: 58 image  Ally Member
    What is your IP address for both interface on NAS and what is the IP address of your PC?
  • Mijzelf
    Do you mean that you are not using a switch when connecting through gigabit? That can be done, but both PC's should be in a different subnet, and so should be the ports on the NAS. Else the NAS won't know which port to use to reach a certain PC.
  • atopos
    Most probably that is the problem then, could anyone post "reccomended settings" for lan1/lan2 (on the zyxel) and for the 2 Ethernet adaptors of the PC's?
    For example->
    Lan 1
    Ip address->?
    Subnet mask->?
    Gateway mask->?
    Primary Dns->?
    And what should I input on the Ethernet card on the PC
    Ip address->?
    Subnet mask->?
    Gateway mask->?
    Dns->?
    P.s The 2 computers get internet through WiFi so Ethernet won't interfere with other settings.
    Thank everyone for helping!
  • Mijzelf
    Lan1:
    IP->192.168.10.1
    Pc1:
    IP->192.168.10.2
    Lan2:
    IP->192.168.11.1
    Pc2:
    IP->192.168.11.2
