NAS326 problem - part 2 - help is needed - Volume is down
Janikovo
Janikovo Posts: 24 image  Freshman Member
edited June 2020 in Personal Cloud Storage
Hello all,
and especially @Mijzelf
You probably know my problem with one faulty disk on NAS326 (linear, jbod).
Look here: https://homeforum.zyxel.com/discussion/3827/nas326-problem/p1
Problem is how to "assemble" NAS volume (or array back) without losing data.
So, I managed with ddrescue copied 99.999% of that faulty disk to the news HDD same size.
Installed the new disk to NAS, but the situation is as follows:
What should I do now ?
Please an advice
and Thanks.
#NAS_June_2020
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    The array is assembled, but it fails to mount. So try running fsck:
    e2fsck /dev/md2
  • Janikovo
    @Mijzelf
    ~ # e2fsck /dev/md2
    e2fsck 1.42.12 (29-Aug-2014)
    /dev/md2 is in use.
    e2fsck: Cannot continue, aborting.
    Thats all.
  • Janikovo
    edited June 2020
    OK,
    i tried add -n to e2fsck
    and it show this:
    ~ # e2fsck -n /dev/md2
    Warning!  /dev/md2 is in use.
    ext2fs_open2: Bad magic number in super-block
    e2fsck: Superblock invalid, trying backup blocks...
    e2fsck: Bad magic number in super-block while trying to open /dev/md2
    The superblock could not be read or does not describe a valid ext2/ext3/ext4
    filesystem.  If the device is valid and it really contains an ext2/ext3/ext4
    filesystem (and not swap or ufs or something else), then the superblock
    is corrupt, and you might try running e2fsck with an alternate superblock:
        e2fsck -b 8193 <device>
     or
        e2fsck -b 32768 <device>
    btw:
    mdadm --stop /dev/md2:
    ~ # mdadm --stop /dev/md2
    mdadm: Cannot get exclusive access to /dev/md2:Perhaps a running process, mounted filesystem or active volume group?
    So, I cant stop md2
    How could I assemble volume (array) without losing data ?
  • Mijzelf
    So, I cant stop md2
    You can't stop md2, because it's busy. md2 is not mounted, so there must be something else. I should have looked further, apart from md2 there is also a dm-1 in /proc/partitions, which is slightly smaller than md2. So inside your raid array there is a 'logical volume', and that logical volume is the one containing the file system.
    So try
    e2fsck /dev/dm-1
    I am not sure if that dm-1 devicenode is inside /dev/. If /dev/dm-1 cannot be found, try
    find /dev/ grep dm
    to find the path to the devicenode.
