Print server on NAS542
eried
Hi, I havent been able to use my printer (which worked with cups in Raspberry Pi). My printer appears "Offline" and if I try to delete it or rename it I get Error 500
How can I reset cups in the Nas542? I tried via SSH but I just get permission denied trying to delete the .conf files related with the printers
Have you tried to reboot NAS? Did you use root or admin to SSH NAS?1
Yes rebooted several times, and also upgraded the firmware to latest yesterday. BUT! I was admin.
As root I was able to delete those files! yay! thanks a lot.
I will check if I can make the printer work now. :'( vi is horrible, I wish uboot had nano at least.0 -
OK, so how I fixed this:
1) Unplug the printer
2) Delete etc/cups/printers* in SSH
3) Delete the current printer in /etc/zyxel/py_conf (leaving [[[printers]]] header empty)
4) Reboot the NAS
5) Plug the printer
Do not change the name or do anything with the printer. It does not work and everything get stuck. After this you can add the printer in Windows with:
http://nas_hostname:631/printers/Name_displayed_on_config_copy_with_edit(but dont edit it)0
- 588 USG FLEX H Series
- 477 News and Release
