Mobile router Zyxel LTE2566: Not able to connect to a network when abroad (roaming issue)
eltorno
Hi there!
I am experiencing some problems with my mobile router Zyxel LTE2566. In my home country (Switzerland) everything worked perfectly - I inserted my SIM card of my domestic provider and the hotspot provided me with mobile internet. However, now that I am in Italy, I have problems using the same (Swiss) SIM card. I switched the „roaming“ option to ON on my zyxel router, and it gets cell covered from the Italian provider, but the internet doesn‘t work. Furthermore, the router also frequently disconnects when I am in the router settings („device disconnected - please check network“
Anyone an idea how to overcome these problems? Do i need to set an APN manually? I am having a SIM card from the same Swiss provider in my mobile phone, and there everything works perfectly.
Cheers
Cheers
Hi Mia. Thanks for your reply. I already tried to manually set the APN, didn‘t help0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
