NAS326 Upgrade HD and keeping old files
Nickba
Nickba Posts: 17 image  Freshman Member
edited July 2020 in Personal Cloud Storage
I am trying to upgrade my internal HDs on my NAS326. When I remove the internal HD and connect as external USB, I cannot access it(it shows as unformatted). It is not RAID, it is just a simple volume. Is there a way that I can connect an internal HD as external to copy the files to the new installed HD?
#NAS_July_2020
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    Even if you configured a 'simple volume', the NAS puts a single disk raid array on it. To be able to mount that, you'll have to assemble it.
    Assuming you have one internal disk, the external disk will be sdb. On a 326 the data partition is the 3th one, so that is sdb3.
    Assemble the array:
    su
    mdadm --assemble /dev/md4 /dev/sdb3
    When that succeeds, the array is either automounted, or you have to mount it manually:
    mkdir /mnt/mountpoint
    mount /dev/md4 /mnt/mountpoint
