Ich muss mein Handy platt machen. Wie kann ich die Multi Accesspoints über Internet bedienen?
Silvio
Silvio Posts: 1 image  Freshman Member
edited August 2020 in Multy WiFi System
Multi
#Multy_Aug_2020
  • Zyxel_Eric
    Zyxel_Eric Posts: 279 image  Zyxel Employee
    First Answer First Comment
    Do you mean that you want to access your Multy from WAN without your phone?
    If you have Multy Plus, you can access the web interface of Multy Plus from WAN by its WAN IP, but you will have to make sure the WAN IP is a public IP, otherwise, you may need to set a port forwarding rule on the Router/Modem.
    However, if your device is Multy X, it only supports App management, it requires the phone to manage your Multy X.
