Recycle Bin does not work when deleting from Windows File Explorer on Zyxel NAS542
Plecto
I've enabled the recycle bin. Deleting files in the Zyxel file explorer moves the files to the recycle folder, but deleting files inside the network share in Windows 10 seems to delete the files permanently. Is it supposed to be this way?
How did you delete your file from the file explorer?
I always delete my files from file explorer by access \\nas542\, and the bin always has the files that i deleted.0 -
Plecto said:I've enabled the recycle bin. Deleting files in the Zyxel file explorer moves the files to the recycle folder, but deleting files inside the network share in Windows 10 seems to delete the files permanently. Is it supposed to be this wayHa?
Can´t confirm that. The recycle bin will created and show up as shared folder even in a mapped NAS after you have deleted a file, as I did within Total Commander, and you can recover it from there as well as you can do within the file browser in the NAS.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
