Zyxel multi u setup dont give input for network name and password
cocoon
so i use the multi app on my huawei p30 it connects to the device ok and says you can now proceed to created your wifi network..Then it will without any input create a network and i guess set a password..and then when finished say all is good.. unfortunately only the mobile with the app can connect to it..All other devices dont have password for the wifi..And the mobile with the Multy U app can connect and get to the home screen where it only says disconnected and can't enter settings or see anything...So cant find password or set wifi name or do anything...And i understand there is no web gui and no way to connect to this shit and setup things yourself.. This app thing must be the most strange thng ever when any web gui can setup a wifi within seconds..Factory resetted and tried 3 mobiles all with the same result..Wifi network created!! Hurray but no way to access password or change anything.... Is there a way to connect to it via PC and CLI or some client? Must be a way to setup this without the flawed app and bluetooth....
Dear Sir,1. What is your network topology?2. Can you provide how do you reset your Multy device and Multy APP?Here is the FAQ how to reset Multy U3. Can you record a video about your issue on the home screen of your multy APP? Can you explain more details about your previous message(And the mobile with the Multy U app can connect and get to the home screen where it only says disconnected and can't enter settings or see anything)4. What is your multy app version on the mobile?5. To change the wifi password, you can refer to this article step19 and step20
6. Please send the feedback to us from the Multy App.Best regards,Jerry0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
