NAS326 bootup very slow ~ one hour
Were you suspecting this?
It's the only reason I could think of why chown -R on a healthy disk and filesystem could take an hour.
Is this a known (mis-)behavior?I don't know. I never heard of it, but I'm not very Plex. I only wrote the installer script, on instructions of someone else. Never used it, except for testing if the installation succeeded.Maybe you could ask in a Plex forum.0 -
Yes, I will pursue it in the Plex forum.
Thank you VERY much for your great help!!!0 -
Did you manage to resolve the case? I'm dealing with the same issue, NAS326 and Plex » 35-45 minute waiting from turning on to the "beep".pdpbjorn said:Yes, I will pursue it in the Plex forum.
pdpbjorn said:
/ $ find /i-data/sysvol/.PKG/PlexMediaServer/share/PlexMediaServer | wc -l 485990
in my case its around 80000
If you can find the leaked files, you can add a remove to the start script. It can't be hard to recognize them, as they must have an auto-generated filename.0
- 588 USG FLEX H Series
- 477 News and Release
