Problem first time configuration Multi X
RibeiroRogerio
i have a problem with the configuration, when the configuration is complete and i try to add a second node, I have a syncronization error.. and I have to reset the configuration.. if I ignoramus's the second node, the app appears as disconnected.
#Multy_Oct_2020
#Multy_Oct_2020
Dear Sir,To clarify the issue, here are some questions that need your response1.What is your network topology?2.After reset the device and re-install, have you ever seen the screen below on the multy APP?
3. Please refer to the article to reset the Multy device, and make sure all the steps are following the guide.If you have some issues with the installation steps, please feel free and let us know.
Please send us the feedback on your multy APP, we can help analyze the log to your issue.Click the send feedback button on the multy app, the multy app will generate the log of your multy device.Best regards,Jerry0 -
hi,
1 the Multy is connect directly to de modem.
2 no the screen above is not shown.
Dear Sir,We do not receive your feedback from the multy app, please send us the feedback.we can help analyze the log to your issue.Click the send feedback button on the multy app,the multy app will generate the log of your multy device.Best regards,Jerry0
- 242 Nebula Ideas
- 6.8K Security
- 765 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 526 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
