Why Zyxel Multy Plus does not retain the LAN IP
Tenttu
Hi!
I just installed Zyxel Multy Plus and tried to assign 192.168.10.1 as the LAN IP (via the web GUI) and applied the settings. Then I wait a bit until the device has done applying and check the situation again; it shows 10.0.0.1 again as the LAN IP.
I tried to change the LAN IP for a few times and always the same thing, it just reverts back to 10.0.0.1, why is it doing this? Am I missing/overlooking something or is this a bug or something like that?
I greatly appreciate any help regarding this matter, thank you!
Kind regards,
Tenttu
Kind regards,
Tenttu
Hi Jerry!
I actually solved the problem myself by just resetting and setting the device up again. I didn't try this right away because I had just installed it in the first place. Still as I know there aren't any other devices in the network that could've caused the problem, I decided to try and do a factory reset and set it up again.
After the device was set up and running again, I went and changed the LAN IP and everything works like a charm. I have no clue what might've caused the problem as everything was like before and I also did everything like before.
Anyways I'm just glad I got it working, that's most important.
Thank you, stay safe and have a great weekend!
Kind regards,
Tenttu0
Dear Sir,
Please kindly provide your network topology.
We suspect there is a conflict subnet on your Wan and Lan.
Could you check your IP address on your WAN interface?
You can refer to the below KB article
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=018001&lang=ENBest regards,
Jerry0 -
Hi Jerry!
Kind regards,
Tenttu0
- 441 Beta Program
- 293 Service & License
