Does Multy X support Amazon Alexa VUI?
POP
Does Multy X support Amazon Alexa VUI? I want control my Multy using voice commands.
@POP,Yes, Multy X supports Alexa.
You can control your Multy X network with your voice.
Please refer to the link: Alexa Skills of Multy X- Turn on or off the LED
- Turn off guest WiFi
- Pause the Internet
- Check your Internet speed
The skill does not work for months. Alexa either says "I'm afraid I don't know," or she breaks off with a sound. Will it ever be fixed?
Does the Alexa deivce always has the problem?
You can try to said : "ask my multy ....." to test if it works.0 -
Sorry for the late reply. Yes, it always has the problem. The latest Echo Dot 4 has the same problem. It always says "I'm afraid I don't know" or "This is not yet supported" or she breaks off with a sound. Until several months ago it still worked.I have disabled and enabled the skill several times, but it doesn't help. I have noticed that after activating the skill I am not asked to link my account again. It is automatically linked. Could it be related to this?
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
