nsa320 problem with utility
Jakub Střítežský
own nsa320 and i have a problem connecting with the utility. I insert the disk, connect the NAS cable to the PC, turn on the NAS. in windows 10 in zyxel utility i can't see server. I tried it even without disk, hard reset, another PC, firewall disabled in PC. did anyone know about it?
Can you ping your NAS ?If you can ping it, I recommend you check it's SMB service and it's port 139 are opened.If you can't ping make sure it can get IP address.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
