Multy X | WSQ50 | V2.20(ABKJ.4)C0 Release Note
Zyxel_Eric
how can i update the new firmware?0
Hello @9618lin
The user guide at ftp://ftp.zyxel.com/Multy_X_(WSQ50)/user_guide/ should help you to use the Multy APP to manage your devices including using it to update the firmware.
I hope that this is helpful.
Kind regards,
Tony
Hi @9618lin,
The firmware will auto-upgrade to the latest one if you're freshly installed.
If there is a new firmware, it will pop-outa a message inform there is a new firmware and ask if you would upgrade it or not.
Best regards,
Jerry
- 588 USG FLEX H Series
- 476 News and Release
