Multy X | WSQ50 | V2.20(ABKJ.4)C0 Release Note
Zyxel_Eric
Zyxel_Eric Posts: 279 image  Zyxel Employee
First Answer First Comment
  • 9618lin
    9618lin Posts: 1 image  Freshman Member
    how can i update the new firmware?
  • tonygibbs16
    tonygibbs16 Posts: 977 image  Guru Member
    Hello @9618lin
    The user guide at ftp://ftp.zyxel.com/Multy_X_(WSQ50)/user_guide/  should help you to use the Multy APP to manage your devices including using it to update the firmware.
    I hope that this is helpful.
    Kind regards,
         Tony
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,401 image  Zyxel Employee
    Hi @9618lin,
    The firmware will auto-upgrade to the latest one if you're freshly installed.
    If there is a new firmware, it will pop-outa a message inform there is a new firmware and ask if you would upgrade it or not.
    Best regards,
    Jerry
