Plex for NAS326
I'm not sure. The 'hf' version should always work, but the 'hf_neon' version is (slightly) faster, when the CPU supports neon.To find out if the CPU supports neon, run
grep neon /proc/cpuinfo
It seems that my NAS326 supports "neon" so probably the best is to install that version!Thank you!0
Hi everybodyI had a problem on 2 disks on my NAS326, now I've already replaced the disks but PLEX is damaged,tring to reinstall it receive an error that I can't solve.help meee!!
Hi @Nico,I don't know if I can help you but have you tried to check the path and see if there is anything in there or if you can place the *.spk file?It seems that the path is wrong at least compared to mine which stores the files in: /i-data/{diskID}/.PKG/PlexMediaServer/share/PlexMediaServer/tmp/InstallNo other "tmp/tmp/rnxtmp" folders...Have you updated the Plex App and/or NAS's firmware?That's all coming in mind...0
I've updated the firmware
(I've the same directory tree that you say)
Hello again @NicoIt seems that the directory tree is the same for both of us.I don't know why your Plex installation is looking at another directory (the one shown on first screenshot) or if this is an irrelevant message. That's why I said before to update or even better re-install the app.What also worries me is that your "ls -la" command shows an input/output error which generally means hardware problem and you have said that had disk problems....Have you replaced all failed disks, rebuilt the array (if one is used) and checked the filesystems? Check to see "dmesg" what it prints and if there are any other hardware errors...I would start from there...Sorry for not being able to help more.Regards0
Nico said:Can use the folder /admin/MyRepo/ to install a 3rd part application?
whitch type of app have I use? (.apk .rpm?) @MijzelfYes, but unfortunately only zpkg. The MyRepo directory is treated as one of the repositories that MetaRepository includes.I use(d) it to test my packages before uploading them to the online repo.0 -
Hello. Installed PLEX on NAS 326. When you press the start button, an error appears. What did you do wrong and how to fix it? Thanks.0
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
